Best Suspension for $800?
I have an 85, 944 and I'm looking to upgrade the suspension but I only have roughly $800 to spend. I want something good, not kyb or any crap like that.
I was thinking Koni's and 250lb lowering springs up front and Koni's in the rear? What would be the best combo for my price range? Also what are the best and cheapest sway bars I could put on? Thanks everyone!! |
you're not going to get very far for $800. you have to factor in an alignment when changing struts, or even just lowering the car. that will set you back $200 all by itself for one that is worth anything.
for $800 you can buy front springs, rear shocks, the alignment, and a used set of bigger swaybars, but you have to install it all. |
AFM #725
Save up to about $1,200 and you could get a Koni coil over setup from Ground Control. Any spring strength you want and adjustable. $800 is about what you will need to just get the front and rear dampers. Another couple hundred for springs
I doubt you can even do that much. You want to upgrade it right? $800 might get you a set a struts. There's the front and rear alignment, the front and rear swaybars, rear shocks, springs, ALL of the rubber. I don't know if strut mounts have to be done, but they're $490 each. Also, when getting the cheapest option you are getting nowhere near the best. I'd suggest doing everything in phases. Do shocks now, sway bars a little down the road, etc. That way you can get the setup you really want instead of going the cheaper route.
Misunderstood User
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Jcommin: Lol @ "misunderstood user". Sounds like that Merc saved you. Amazing, glad it did!
Yea. Make some friends at an alignment (better yet, Porsche) shop. +1 on the used sways and new Konis. Maybe front springs. Or..... Take the 800 and do a trackday. Get a helmet, makes sure you have good summer performance tires, good pads, and do a trackday. Then think about suspension. Unless your shocks are really bad. Take care! Last edited by FrenchToast; 02-19-2013 at 03:31 PM.. |
Non Compos Mentis
Also I would be doing all the work with a friend. |
What would be the difference between these and Weltmeister 250 lbs Autocross Springs? Also how do you quote more than 1 message in a single reply? lol I'm pretty new to the site. |
slim chance that quote is worth anything. i'd be surprised if they even have the special tools required. i see shops all the time quoting on these cars, and it usually turns out to be a toe set only, and/or some lame excuse about something so that they don't actually have to align the car. it's hard for a shop to make money with a price of $120.
it takes about 2 hours to do an alignment on this car. you start with setting the rear ride height. this is what slips up most of the shops. whatever the shop hourly rate is, assuming they have the tools, you can count on that hourly rate for 2 hours. be sure to do the alignment with the car loaded as it is normally driven, about 1/2 tank of gas, and your weight in the driver seat. |
Thanks for the insight. |
i hate seeing people get screwed on alignments. be sure to check in advance to make sure they have the eccentric tool and the thin wrenches needed. see if they have the weight for the driver seat, or will let you sit in the car. also ask them when the last time the rack was calibrated. if it's a laser rack, it needs calibration every month.
Misunderstood User
As for my Benz- Got rear ended sitting on the expressway at 35 mph and got pushed into the car in front of me. Both cars were company cars and the owners were talking about what they were going to get as a replacement while looked at my crumpled mess as it was being pull up onto a flatbed.
AFM #725
Also what would be a good size for sway bars?
What's a good price for them? What is all the necessary hardware needed for them? |
[QUOTE=Mike_944;7283331
Also how do you quote more than 1 message in a single reply? lol I'm pretty new to the site.[/QUOTE] Use the (multi link quote this message) (''+) it will turn red when you click on it.Btw I got a lot of suggestion for a $800.00 to $1000.00 suspension upgrade but probably they will be to conservative for you.If you care to check my garage go ahead (click on garage then on (Old Faithful) my ex 83 & see the mods I had done to it)
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
$800 is not going to get you far. It probably won't even cover a decent set of tires and a good alignment. Save up some more and buy a decent set-up rather than trying to cobble together a compromise based on budget. Just advise not critisism, take it or leave it, GL
I already have new tires. I was more just seeing how far I could get with $800 rather than getting everything at once. |
AFM #725
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
| Tags |
| koni , shocks , springs , suspension , sway bar |
