Mike_944's Avatar
Originally Posted by Gawernator View Post
I think you'd be happiest with rubber and it's less expensive. In fact if you want I will sell you my bilstein HD shocks for cheap, they're about a year old. I was going to sell them anyways. Then you only need to buy struts
PM me!
Old 02-21-2013, 05:08 PM
1983 944 N/A
POPS 83 944's Avatar
Here is a good link a bought suspension
Suspension
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 02-21-2013, 05:24 PM
1983 944 N/A
Originally Posted by Chunkerz View Post
They're $268 from Weltmeister, but I saw a thread where someone used VW torsion bars. They were about half the price of Weltmeister or Sway Away torsion bars and worked fine.
Here is the post a bought the VW torsion bars
944/VW Torsion bar interchangeability... - Rennlist Discussion Forums
Old 02-21-2013, 05:32 PM
AFM #725
Gawernator's Avatar
I pm'd you
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-21-2013, 09:25 PM
Dimi 944's Avatar
If the car is street driven you can go with Weltmeister bushings BUT they will be destroyed if you track the car for prolonged time. If you want to go a step further, I'd recommend Delrin bushings at the spring plates, sway bars and front control arms. Delrin bushings are much more affordable comparing to the racing poly-bronze and all metal ones and they are much better than the urethane bushings too.
I have replaced most of the bushings on my car with Delrin and I am quite happy with no issues over 4 years of track only driving. Some of the bushings were made by my business partner. I plan to have the rest of my stock bushings made and replaced by Delrin ones as well.
Originally Posted by Mike_944 View Post
While I'm replacing the suspension I would like to take care of all the bushings and small parts that are worn.
What would these be and what are the best ones to buy?
Dimi Paralanov
Flying Horse Motorsport
flyinghorsemotorsport@gmail.com
Old 02-22-2013, 07:06 PM
AFM #725
Gawernator's Avatar
You have a PM
Old 02-22-2013, 11:51 PM
Makis's Avatar
I use coil over allrouond and lowered my S2 by about 35mm. I kept the rear torsion bars as is but reindexed them by one notch so maths calculation where kept minimal. One notch on one side drops the car by 2 inch and can be done easier as you don't have to remove the bars from the car. With 2 inch lowered at the rear, coilover can then be used to raise the car back a bit and still have it lowered and sitting on stiffer overall springs. I use 10.5 inch, 225lb spring at the front and 9inch 160lb springs at the rear and is fine for road use. I will need stiffer springs for competition use.
I would say going 250lb springs at the front without doing anything at the rear will be bad choice. Would go max to 175lb springs at front without altering the rear.
Old 02-23-2013, 04:03 AM
Tags
koni , shocks , springs , suspension , sway bar
