AFM #725
Gawernator's Avatar
Rebuilt my throttle body
So... It took me five hours but I rebuilt the throttle body and replaced the TPS. It feels like the engine "revs more freely" and accelerates better. Seems like I am getting a bit more power with less use of the pedal. Does that make sense or is it cognitive bias in my imagination? What positive results should one expect from these two procedures. Also my idle is now rock solid at about 950 RPM, it used to randomly wander a little bit. When driving if I went to neutral the RPM would drop to 1,000 then to 950 when stopped. Now it goes straight to 950? I didn't even take pictures of the seals I removed. I couldn't. It took an hour or two with a pick to get everything fully out really. It was a goopy disintegrated mess and the o rings came out in micron sized pieces. How frustrating.
Old 02-19-2013, 01:13 PM
Proprietoristicly Refined
John_AZ's Avatar
Nice job!
When I did mine, I was surprised how bad the throttle shaft "O" rings were.
I peened the screws very carefully on the shaft.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-19-2013, 08:46 PM
AFM #725
Gawernator's Avatar
John, when you rebuilt yours was there a lot of oil/gunk/sludge in and around the seals and inside the TB?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-19-2013, 08:50 PM
John_AZ's Avatar
I had a little, then I replaced the AOS seals +"O" ring on the dip stick + new clamps on hoses under the intake plus a few WYAIT items and all is dry and clean now.
Dried out/leaking AOS seals will cause an oil deposit on the TB.
Next project?
J_AZ
Old 02-20-2013, 04:10 AM
AFM #725
Gawernator's Avatar
Yes. I can't believe the total is $41 for three o rings and two small hoses.
Old 02-20-2013, 08:14 AM
White and Nerdy
Tervuren's Avatar
Yes, if you had a leak, it could make quite the difference.
Shadilay.
Old 02-20-2013, 09:53 AM
AFM #725
Gawernator's Avatar
I must have had a leak with what was basically no seal even left lol.
Old 02-20-2013, 11:15 AM
Mein Gott!
Panzer909's Avatar
Did you buy that Arnnworx kit? I've been meaning to do this but the TPS assembly on the S is a B*TCH to work on.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 02-21-2013, 01:21 PM
AFM #725
Gawernator's Avatar
Yes I did. It comes with nice hardware.
Old 02-21-2013, 02:40 PM
