Exclamation Help! Front driving/fog lights
Can someone please help me. I have an 83 944 with the front driving lights stuck on. I've removed the fuse from No.15 position, still on. I've removed the switch from the console/dash (below the 3 guages), still on!
Am at a loss as to why this has just happened, car on lights are on, car off lights are on, key in ignition or out of ignition lights are on. There has been no modifications to the lights, and no electrical modifications apart from a stereo upgrade 2 years ago. Has anyone ever had this problem?
Thanks in advance,
Martyn
Old 02-11-2013, 08:39 PM
Custom User Title
mikepellegrini's Avatar
Sounds like a short, or something. I presume they were working using the switch earlier?
You can isolate the circuit they're on by removing the other fuses one by one till you find it.
I'm not sure what you do when you find it. I'd be thinking about maybe wiring around it.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 02-11-2013, 09:25 PM
It must be a short in the fuse box from the fog light side of the fuse to the fuse next to it. Try pulling the adjacent fuses.
Old 02-12-2013, 05:17 AM
honerboys's Avatar
there is also a relay for the foglights up above your right knee - could be it's stuck - it's up there pretty good - if i remember it's a black plastic one about 1 x 2 inches
84 928 S - SOLD
2012 Cayenne S
Old 02-12-2013, 05:11 PM
Thanks for those replies, still hunting, what a ***** to get the No.15 fuse back in! Am going back underneath to try & locate that relay, will get back to you all soon:-)
Old 02-14-2013, 09:28 PM
honerboys's Avatar
it looks like this - good luck
84 928 S - SOLD
2012 Cayenne S
Old 02-15-2013, 10:17 AM
Thanks so much for that. It wasn't that relay after trial & error, the fog lamp relay, called the "additional headlight relay" was mounted on the fuse board. So.... I've now replaced that and got front fog lights but have now lost my RH park lights, front & rear. I've replaced the bulbs thinking that maybe that was the fault but no, anyone else had this problem?
Thanks so much for helping:-)
Old 02-15-2013, 08:15 PM
CatsEyes's Avatar
This is kind of random, but it may just possibly help.
If I leave my turning indicator on when I turn off the ignition, the front parking light (and I think rear light too) go on and stay on on the side that the turning indicator would have been on. (If that makes sense.)
I've no idea if this is a wiring issue in my car, or some weird Porsche feature. I never thought about it much, since it otherwise affects nothing.
But it does suggest the wiring for the front parking lights and rear lights must be either connected to, or capable of getting messed up with, the turn indicators.
That would possibly explain your most recent symptoms.
I doubt this will help, but just in case...
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II'
1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten
'Hell is previous owners.' (anon.)
Old 02-16-2013, 02:03 PM
The front and rear turn signal lights will stay on for the side the turn signal switch is selected to with the ignition off by design. This is a "safety" feature that allows the side of the car facing the street to be illuminated on narrow streets at night time to reduce the chance of the car from being hit.
'86 944 Turbo
You have to be a masochist to love something so frustrating.
Old 02-16-2013, 06:10 PM
AFM #725
Gawernator's Avatar
Ditto, my car does the same. Didn't know it was a feature, first time it happened I was a bit concerned
Old 02-16-2013, 08:36 PM
This is an Europen Feature for road side safety.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-16-2013, 09:28 PM
Am going to "dive" into that fuse box again to see if there's anything else wrong there. Everything looks clean tho, 42,000 mile car that's always been dry. Hopefully it's just No 13 or 14 fuse. Haven't tried the European park light feature so once I've found this problem will try that as all cars sold here in NZ would have been Euro spec cars.
Old 02-20-2013, 01:15 PM
CatsEyes's Avatar
You might want to look through the wiring on the underside of the fuse-box, too...
Old 02-23-2013, 03:38 AM
