87 944S overheating
That 944S that I had that broke a chain guide and messed up my valves, finally finished it and started it, runs perfect, only one small problem: it's overheating. Gets pretty warm, and I undo the vent bolt a little bit and air/steam comes out. Did that a few times, getting air/steam every time, and a lot of it. I'm not sure that is just the air that was in the cooling system or if that is just the steam that forms when the car start heating up. Water pump had been working fine engine rebuild. Any suggestions?
Here's a pic of finished product. By the way, thanks to all those who helped me along the way.
Old 03-02-2013, 04:40 PM
Thermostat staying closed? Does the radiator hose the runs to the thermostat feel real hot when the car is warmed up like fluid is traveling through ok? Is it possible to put the headgasket on backwards thus covering fluid travel? I am not familiar with the S motors. Only other thing that I could think of is you still might have an air pocket in there.
Old 03-02-2013, 04:58 PM
Yep, the hose is indeed very warm. I don't think I put on the head gasket on wrong because there was really only one way that it could go on.
Old 03-02-2013, 05:00 PM
Sounds like the thermostat is operating correctly then. Was the head pressure tested on rebuild? Doubt it but there could be a crack in the head that is causing the raisng temp? I believe that to bleed the air out either the front or the back of the car should be raised to help get the air bubbles out when bleeding. I can't remember which though but I didn't have to do that when I did the water pump job on my 83 NA 2.5.
Old 03-02-2013, 05:08 PM
The head wasn't pressure tested, but I really hope that it doesn't have a crack. Well my driveway is sloped, so I'll try bleeding both ways.
Old 03-02-2013, 05:12 PM
AFM #725
Gawernator's Avatar
Do you have a coolant pressure tester? Would be quite handy. Also a free loan from AutoZone. And you're supposed to raise the front up but I don't think it matters when you use a coolant pressure tester.
Old 03-02-2013, 05:41 PM
rickharrison's Avatar
My bet is air in the system...get the front end up high when bleeding it.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 03-03-2013, 06:18 AM
was the intake and cover powder coated, and bleed it till coolant comes out.
Old 03-05-2013, 04:16 PM
No, they weren't was powder coated. I had a friend do it for me, blasted the whole thing used some high temp stuff.
Old 03-05-2013, 10:27 PM
porschetub's Avatar
X2, groundhog day on this issue
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-06-2013, 12:52 AM
