-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Damn PO!! Center console... (http://forums.pelicanparts.com/showthread.php?t=736810)
Mike_944 03-02-2013 02:43 AM
So the PO spray painted the center console with high gloss black paint and dirt just sticks to it and won't come off and it looks tacky.
My question is, is there anything I can do to refinish it back to original specs or at least a lot closer? I want to avoid buying all new console pieces.
Thanks!
iplagolf 03-02-2013 03:33 AM
I'd be very careful of most paint strippers because of the chance that they will melt the vinyl. There is an orange based stripper, I can't remember the name of it, that may work. Check at Lowe's or Home Depot for it. Test it on a scrap piece of vinyl to see what it does to it. Good luck.
iplagolf 03-02-2013 03:40 AM
OK, I'm a little more awake now. It's called Citri-Strip. It contains no methylene chloride. Stays wet (stripping/working) for up to 24 hours on the surface. You can use it inside, no nasty fumes. Let us know how things turn out.
zedsn 03-02-2013 04:42 AM
rustolium has a line of rattle can paint that can also be used on plastic. Maybe buy a can of flat black and try it.
iplagolf 03-02-2013 05:52 AM
Yeah, I was thinking about the paint for plastic also. I think the old stuff would need to come off first. After it's removed I don't know if it could be re-dyed or not. Is it black or another color? I've re-dyed leather seats but not vinyl. It could be you could recover it like you would a cracked dash.
zedsn 03-02-2013 05:57 AM
if you have vinyl to paint I would recommend SEM in a rattle can. They come in different colors. Rustolium has a line of paint that is different colors that is also suitable for plastic so they say and I have seen it at home depot.
ernie9944 03-02-2013 06:53 AM
Thanks!
That old paint will be very hard hard to remove without doing any damage to your vinyl.Remove the consol cover -wash with soap & water then get a can of SEM Color Coat Satin Black # 15243.First spray a thin coat,let it dry for about 30 minutes between each coats until you get the proper color finish.Should take about three coat to get it rigth.Pics of my shifter & boot done in Satin Black.:Dhttp://forums.pelicanparts.com/uploa...1362235755.jpg...Before (Grey)
http://forums.pelicanparts.com/uploa...1362235826.jpg...After (Satin Black)
ernie9944 03-02-2013 08:26 AM
Mike___ forgot to tell you,if possible find a small bottle of TANA (usually available at shoes maker shop) once wash treat your cover with it before spraying.It will help the SEM to bond to the old paint.Beware TANA is very strong & smelly so you'll have to do this in an open space wearing hands & breathing protection.This stuff dry very fast in about a (couple of minutes).Have fun:Dhttp://forums.pelicanparts.com/uploa...1362241485.jpg
iplagolf 03-02-2013 09:41 AM
You don't have the year of your car listed, but in the used parts site here a seller under "parts for sale" has a console in black for an 88 for sale.
Gawernator 03-02-2013 09:59 AM
I agree with the above. Just paint over whatever happened.
ernie9944 03-02-2013 11:28 AM
Probably be the way to go ,buy a use one but 95% of the time it will still have to be redone if its use.:D
ernie9944 03-02-2013 11:30 AM
[QUOTE=iplagolf;7305016]You don't have the year of your car listed,
Year of the car is an 85,check his garage.http://forums.pelicanparts.com/suppo...s/beerchug.gif
Mike_944 03-02-2013 07:32 PM
Thanks, I think this is the way I'll do it!:)
How did the seats turn out? Pics?
J1NX3D 03-02-2013 09:12 PM
get a proper black center console from a 924 at a wreckers
Mike_944 03-04-2013 12:35 AM
Got all my supplies and everything prepped. Paint will go on tomorrow. I'll post pics when i'm done!
Gawernator 03-04-2013 01:05 AM
Nice
Mike_944 03-13-2013 08:33 PM
Posted this pic in another thread but thought that I should give an update.
I used SEM satin black and it looks great! Also installed a new double din while I had it torn apart.
Before pics:
http://forums.pelicanparts.com/uploa...1363231914.jpg
http://forums.pelicanparts.com/uploa...1363231960.jpg
After:
http://forums.pelicanparts.com/uploa...1363231987.jpg
Gawernator 03-13-2013 08:51 PM
Very suave
ernie9944 03-14-2013 08:50 AM
[QUOTE=Mike_944;7327482]Posted this pic in another thread but thought that I should give an update.
Came out great Mike.Have you redone your shifter boot Satin Black or your going with another color.:D
Jferr006 03-14-2013 09:00 AM
Don't use high gloss on anthing. I beleive that's why its sticky. I made that mistake in another car and it always stays tacky.
This time I used rustoleum 'Satin' black on my center console and it looks great.. a little shine but, no stickiness.
