944 Floor Repair
I'm trying to get my 944 ready for our inaugural season up here in Seattle. The seat mounts on drivers side are basically gone. See photo.
Suggestions on how I should repair this? Some ideas I had 1) take the bolts down through the floor board - not sure if that is safe 2) cut out the same piece from a donor vehicle and weld in - seems possible 3) mount seat directly to cage - have no idea if that is a practical solution or if the floor would still need to be repaired 4) fabricate some new solution from scratch - seems costly since I can't do the work myself. 5) ideas I'm not even thinking of? Any suggestions? Thanks! Dustin
Current Porsches '10 Panamera 4S, '66 912, '90 928 GT, '83 944 Track Car Past Porsches '06 997 C4S, '68 912, '99 996 C4, '97 Boxster |
Your first pic does not work for me. The second pic doesn't look *that* bad. Is it rusted all the way through?
86 944 NA 2.5 |
No, it's just the top layer. Most guys are telling me angle iron welded on with grade 8 nuts welded onto the back should do the trick.
thanks.
Toofah King Bad
What "season?" Is that a race car? If so, you don't really need the factory mounts.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Yeah, I am turning it into a track car however I still want the seat on rails to accommodate multiple drivers.
Thanks!
