Alternater Question
I know my Alternator is going, its only putting out 12.8Volts
Could the Alternator cause intermediate headlights. Like they will just dim down and stay dimmed. Then as if some of the electrical plugs inside don't work. but when I unplug one side it works. Like my window button. Driver Side works, Passenger doesn't. You unplug driver side button and passenger works.
Just not enough Voltage getting to the button?
Old 03-17-2013, 01:58 PM
I would check all the "big" electrical connections, battery, alternator etc. Sounds like too much resistance caused by corrosion to me.
1987 944 Summer
2006 E90 Winter
Old 03-17-2013, 05:42 PM
Battery is New, Good Battery
Connections are new, ground is good.
Im checking connection on Alternator now.
Old 03-17-2013, 05:43 PM
porschetub's Avatar
You most likely have a bad voltage regulator,put all high load items on,A/C headlights,stereo,heater fan,etc and check your voltmeter,if it dips below 12v the regulator is most likely on the way out,around 13.8v is what you are after @ the battery.
Check all earth connections not just the larger ones,theres lots everywhere.
Good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-18-2013, 11:00 AM
Good luck.
Heater doesn't even have voltage and neather does it in the fuse box
Ac works.lol...
Illl be looking into it due to a lot removed already
Old 03-18-2013, 11:36 AM
