Battery Question
It hit 60 degrees today so I took the 944 out for a 5 mile 80 MPH drive. When I started the volts read 13 volts. When I got home the volts read 12 volts. Is that normal or is my alternator on the way out.
1978 924 The Grey Ghost - 18,000 miles and counting 1987 944 Black Betty - Bringing back from years of abuse |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
That sounds better than the alternator. Where is the voltage regulator located.
Sits at the back of the alternator..... heaps easy fix check the other thread http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/671352-awesome-adjustable-voltage-regulator-kit.html
Might help ya in the short time. |
AFM #725
Also try to make sure it's not just the gauge, my gauge doesn't read that accurately
Has the lower suspected voltage actually given you problems like hard, or slow starting ? I would check the voltage at the battery terminals before a ride, and then after a ride using the headlights, heat, and stereo to see if the system is being drawn down.
An autoparts store can test the battery and alternator while still in the car for free. |
I w ork for batteries plus.
Your alternator should be pushing 13/14 volts. Any lower then its starting to go. Your battery is a 12volt rechargable. A fully charged battery should be 12.5volts or more. If it is bellow 12.5 then its not getting a full charge. Deal with this on a daily basis.
This is a new battery. I do think it is effecting starting the car. It acts like it does not have enough power to start the car.. Is there a right up on what has to be done to get to the voltage regulator.
Take it in to where you got it and tell them your car is having a hard time starting. If your battery is getting a 13volt charge your fine. If bellow that I'd take a look. Check your spark plugs and cap/rotor.could be missing a spark. Couple things to takr into mind with this. |
Can someone tell me the procedure to change the voltage regulator.
Please get this fixed. If you have trouble before fixing, the battery should be charged and then started. Do not attempt to jump start the car. It is very possible that jump starting will cause problems with the ECU.
Have your FLAPS test the alternator before you try to replace the voltage regulator. |
