Hella H4 Halogen headlamp upgrade
I noticed my headlamps getting a little dim, I saw pelican parts has the H4 halogen upgrade. Is it worth upgrading or should I just replace with the original bulb?
Old 04-15-2013, 07:37 PM
Custom User Title
mikepellegrini's Avatar
It could be something as simple as the grounds if your headlights seem dim.
I think the closest grounds to the headlights are on the frame rails right behind the lights.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 04-15-2013, 08:03 PM
1983 944 N/A
POPS 83 944's Avatar
Upgrade is well worth it
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 04-15-2013, 08:05 PM
Toofah King Bad
Rasta Monsta's Avatar
Step one, set up the harness and relays, this alone will brighten your headlights. If you still want more, step two (H4 upgrade) will be easy.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-15-2013, 09:04 PM
That Guy
Techno Duck's Avatar
The biggest improvement you will see is installing a headlight harness with relays like Rasta said. Measure the voltage drop at the headlight plugs and you will probably see it around 12v with the car running (should be 14v), 2v drop at the plug is like a 30% reduction in output from the bulbs.
Rennbay makes a nice 'plug-in' harness that is easy to install. This is the single best thing you can do to improve the light output.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-15-2013, 09:38 PM
mhariush's Avatar
I have a pair of headlight conversions that were installed in a parts car. They're not purple, it was just the mixed light that played with the white control on the phone camera.
Uses H4 bulbs...
$40 shipped
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-15-2013, 10:53 PM
Andrew Gawers' Dad
CHICKS's Avatar
+1 on the Rennbay kit.
Old 04-15-2013, 11:22 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
+1 on the Rennbay kit, hope to install mine this weekend!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 04-16-2013, 11:15 AM
