924---what next?!
Alright. New starter. Check. New alternator, minus condenser, check. Fresh belt. Rebuilt wire harness. New battery cable.
Two wires from alternator to starter, contact with battery cable at starter.
Black wire to top left screw on starter
Red wire to bottom left screw on starter.
Blue wire to alternator.
All wrapped up nicely in a heat protective sheath.
I now have no dash anything. Clock ticks, head lights come on and pop up, car fires up, but no dash.
Turn signals on dash both show illuminated,thats it.
Did i miss something while rebuilding the wire harness? Or did i lose something else that i couldnt see on fire?
Old 05-02-2013, 09:43 PM
I have established the power wire to feed the dash isn't getting power. Is there supposed to be a jumper from the alternator to the terminal on the starter?
Old 05-03-2013, 05:20 PM
Toofah King Bad
Rasta Monsta's Avatar
Your main power feed to the fuse panel should come from the battery, I believe.
Since you are in Eugene, a completely unrelated note:
924Board.org :: View topic - 2013 PacNW International Meetup - Third Annual!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-04-2013, 09:03 AM
Ok well pop quiz.. If the excitor wire doesn't activate, will power run through all the meters still? Tach volt instrument panel ect?
Old 05-04-2013, 01:25 PM
ssschaib's Avatar
I seem to remember something about the battery light bulb being a resistor for the circuit and if it is blown, things don't work. Might be totally irrelevant.
Old 05-04-2013, 05:10 PM
Toofah King Bad
Sounds like you could use a wiring diagram. . .I think they are on Pelican someplace.
Old 05-04-2013, 11:08 PM
yarfk
kfray's Avatar
http://www.pelicanparts.com/944/electrical/924_78_1_1.jpg
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 05-05-2013, 05:15 AM
I've wired everything according to the wire scheme. I found a lot of the wires in the dash fried too. I did a quick patch of wires and regained all my clusters, but alt was only reading out at 10v and excite wire still had a weak connection. I'm replacing the wires best I can. Is there any where else I should check at this point?
Old 05-05-2013, 01:14 PM
Wires replaced. Still coming out at 10v...
Old 05-05-2013, 01:46 PM
so incase anyone comes across this and says well what did that idiot do next... well I was going off the volt meter in the car. I bought a multi meter later. My voltage meter in car reads at 12v now. My multi meter reads 14.1v at the battery while running.
At that, car should be in operable running condition now right? could have the electrical fire just messed with the in car meter?
Old 05-06-2013, 08:22 AM
fiat22turbo's Avatar
Behind the center gauge cluster, add another ground lead to the firewall behind the center speaker:
Electrics
Also triple check the ground blooms behind the dash, they corrode at the drop of the hat. Clean them up and add some vaseline or dielectric grease to protect them.
Hope to see you at the Portland Historics!
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 05-10-2013, 01:49 PM
