944 coolant leak?
1983 944 is leaking fluid that drips from the front end of the cat converter. I'm thinking coolant from a heater hose. Any other ideas?
Thanks in advance, Rob
356robo 70 T Targa Looking for a 2.2,2.4, or 89 coupe |
The rubber coolant pipe at the back of the engine is toast. It runs from the heater control valve to the metal coolant pipe that runs over the exhaust manifold. Change the HCV at the same time and cover the hole in the bell housing before you do any work back there. GL
I'm currently replacing all my coolant hoses.. there's about 20 of them...about 7 of them may cause a leak in that area, take your pick
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
AFM #725
Most certainly one of the two rubber coolant hoses that connects at the firewall behind the engine, or the heater control valve.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Mine does this but its clear n tastes like rain water..... ???
This is also where the condensate drain is for the AC.
AJ
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
