Patrick
pfarah's Avatar
Front strut torque setting?
Hey all,
I'm almost done with several repair projects when I decided to replace the rusty nuts (4 on each side), on both front strut towers in the engine compartment, with new stainless ones. The factory manual does not specify torque settings; does anyone know?? I appreciate the help, thanks!
Patrick
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 08-17-2013, 11:59 AM
Frankly my dear....
rhett's Avatar
Spring strut to body - Hex nut M8 - 23nm or 17ft/lbs.
I put stainless nuts here too, did you use self-locking (nylock) ones?
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 08-17-2013, 12:05 PM
Frankly my dear....
rhett's Avatar
I re-plated the washers too as they can look pretty nasty after a while:
Old 08-17-2013, 12:11 PM
Patrick
pfarah's Avatar
Thanks, I just finished replacing them; I'll apply the appropriate torque. As for the wave-style washers, I just used a dremel to remove any rust. They actually weren't in bad shape. In retrospect, I probably should have used the nylon locking type of nut but I didn't, however; a small amount of anti-seize compound was applied to each stud. Sooner or later, I'll have to replace the struts, like everything else. (As anote: the white streak on the red paint is not anti-seize; it's another project to address all the hard to remove spots.
Old 08-17-2013, 01:04 PM
