Repair on Porsches Prices
Im thinking about buying a 83 944 with 85,000 miles.Ive never owened a Porsche am i right in assuming any type repair will be alot more then what im used to .
I know this is a general question but i want to know if buying one is over my head finacially |
Proprietoristicly Refined
Financially speaking,
In your recent post you mentioned the clutch linkage: http://forums.pelicanparts.com/7679605-post1.html It could be a simple $30 used shift lever fix or a complete transmission failure. Used transmissions are about $350 and up plus shipping of $150. Installation additional at $350 and up. Shocks F & R Boge about $400 Tires about $500 for a decent set. +- Basic maintenance -----without tools or skills to change an engine belt. $300 labor ++ The car is DIY and labor intensive. It is 30 years old and needs a lot of attention. Labor starts at $100 an hour +- at a shop You need to replace all of the rubber items front and rear. DIY is just parts cost of $400 ++ (motor mounts and ???) Labor will add $500 ++ What are your mechanical and electrical troubleshooting skills, tool inventory and shop/garage space??. If you have owned a VW, Audi, or any other OLD German import you might have the skills and tools needed. If you need a mechanic to do the work ----pass. GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
AFM #725
Not worth it if you don't/can't do the work yourself. Unless you really are incredibly wealthy and just love 944. But then you wouldn't be asking lol
Patrick
Gaw's got it right. The local P-dealership charges $260.00 for an oil change! Nothing else is included. Buy the oil filter, drain plug seal here and 6 quarts of oil (I'm not going there) from your local parts store. Perform the labor yourself and you'll save $200.00!
If you have any mechanical ability, you'll be able to perform many repairs on the 944. They're, I admit, quite fun to work on...
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
White and Nerdy
My local dealer is pretty good on prices. I guess I'm lucky. That said, unless I'm rushed, I prefer to do the work myself. If you have to ask about the cost, a 30 year old car is probably not for you. You could spend nothing for years, and have a great car, or spend $10K in the first months because things that were working when you bought it, all failed at once. I'd make a working AC a priority if you live in the south. Non-working will often need the whole thing redone, rather than "just a charge". $$$ there. If things go well, expect maybe $500-1K a year. If things do not go well, north of $10k. I have two of them, so I can take my time and put one down until I can take care of what it needs, and driver the other. My 2nd one was bought in non-running condition, not cheap it was to get it on the road, but its a fantastic daily driver for me now.
Shadilay. |
AFM #725
It really can be unpredictable. For instance, my A/C only needed a "charge" and 2 years later it still works!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Back from Beyond
"If you need a mechanic to do the work - pass."
John really summed it up right there. |
Custom User Title
Plus, I'd be suspicious about the mileage. The early cars only have a 5 digit odometer and it's very rare to find an '83 with under 100k miles.
The difference in the kind of maintenance or repairs on a car with 185k miles vs a car with 85 k miles is enormous. |
