What is this hose under the intake, 944S2?
I'll try to post a picture later, but it's pretty identifiable by description:
The hose that goes through the hole in the top of the S2 intake. It connects to a black cannister under the intake, and it has what looks like a pressure relief valve on the hose itself. What is this thing, what does it do, and what is the part number? I need to replace it. Also, what is the part number for the hose on the rear-facing side of the idle control valve (S2) -- the one facing the windshield. It has an elbow bend right off of the valve. Thanks, Tony K.
Tony K. ![]() Lancia - Lotus - Jaguar - Mercedes-Benz (No Porsches at the moment; formerly about a dozen 944s) |
First one sounds like the hose that goes from the top of the throttle body back to the air oil separator (black canister with a long neck on it that comes up near the firewall and terminates with the yellow oil fill cap)? Some of those had a little tee fitting in them with a check valve or a blank plug, IIRC. Is that the first one you're talking about?
'78 924 "NA" '87 944 "S" '93 968 "SC" |
Do you know the part number for it? Thanks, Tony
Looks like hose is on illustration 104-01, part #44: 944.107.311.03, and valve is #45: 944.107.324.00. Might want to double-check with a parts supplier as these hoses changed from year to year, as did the air oil separators.
Thank You!!
![]() - T
