I need help with stall on a 924 please
Hi all, i am an enthusiast and always wanted a classic Porsche, i got a $500 deal on a 924, pretty good shape. Let me tell you what happens to it, i hope you have some ideas, i'd really appreciate any help, in USA the limitations and cost of parts for these European beauties are high.
Problems: Car does start great, after 3 minutes or so it stalls and can't be accelerated, stays on on idle only. Cylinder 4 not firing, new spark plug, new cable, new cap, spark tested and gapped correctly, injector shooting great. Things replaced: Fuel pump, spark plugs, fuel distributor, vacuum lines, all ignition related items. |
i belive thet you don't have prasuure(fuel) right for the engine warm up.
When you start the car the fifth injector works and give +fuel When it warm up probably the warm up regulator close the fuel(pressure) and you have a lean mixture(for running) Look the warm up regulator,on the bigger bolt you have a sort of filter,usuly it is opstrukted after 30 years. Did you change the fuel filter-can be the same problem. The fuel acumulator or the line is opstructed?Fuel pump? -maybe the fue pump is not for CIS-if you have a STD injection fuel pump it pump 3,0 cca BAR.The CIS pump have minimum 5,0 bar. Try.Good luck.
porsche 924 carrera gt 90% ready porsche 944 NA 86' half 951 951 full project for 944 chrysler 300M 6 x 924 and 944 canibalized or death |
You might try searching/posting on the 924Board.org :: Index as that is where the majority of the knowledge around the 924 and its CIS system is concentrated around.
As for your #4 problem, I'd verify that your lifters are adjusted properly and that you have good compression on all 4 cylinders. my 924 came with a bad exhaust valve and I've seen a couple of others with the same issue. Your vacuum and intake systems are vitally important, make sure there are no vacuum leaks before making CIS adjustments. Good luck!
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
