-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Gates vs Dayco timing belt (http://forums.pelicanparts.com/showthread.php?t=785890)
kwikt 911 12-07-2013 09:31 AM
It's time once again for belt change. What's your thoughts on the Dayco vs Gates timing belt. Reason being I ordered a Gates from RM!!!!!!n and got a Dayco. The parts have been sitting in the box since Sept. and I just noticed. They did send me a Gates balance belt though.
flash75 12-07-2013 09:39 AM
I have used both in other applications and experienced no problems with either brand.
Clifton
Gawernator 12-07-2013 09:53 AM
I know Gates is good
924CarreraGTP 12-07-2013 10:56 AM
Get the blue Gates kevlar racing cam belt. It has to be a better bet.
curtisr 12-08-2013 04:45 AM
From Dayco Q&A - Bob is the Oil Guy
Dayco labs question and answers.
Q. I have been advised more than once by different people that Dayco belts are more trouble-prone and that Gates or Contitech should be utilized. Can you comment on the failure rates (massive as well as miles/time to a stretch and/or squeal point) and quality assurance of Dayco versus Gates or Continental?
A. Dayco’s lab tests have shown that Dayco belts are as durable and noise resistant as the competitor’s belt products. Since almost all belt suppliers use belt constructions utilizing EPDM rubber compounds, the flex life and overall durability of belts are very similar. The failure mode that is most prevalent in belt systems is noise, and the cause of the belt’s noise is almost always a system cause (pulley misalignment, low tension, rough/worn bearings,) as opposed to the belt. Dayco has been in business for 105 years and is selling millions of belts every year into the automotive aftermarket and to almost every major Auto and Truck Manufacturer in the world. 105 years of experience has taught us that quality and innovation are the keys to our success and survival.
Ed Rammel, Vice President Marketing
Q. What is the time-life (as opposed to mileage) that a Dayco belt can perform before replacement is recommended? (Important for seldom-used cars)
A. Dayco’s new EPDM belts are not affected by ozone degradation as compared to the older style neoprene belts, thus time for performance will be extended (to at least 7-10 years as compared to the typical 6 years for a neoprene belt). But, storage conditions can still decrease the time recommended, such as high temperatures, high humidity, and/or oil contamination.
Jay Swope, Principle Engineer of Belt Development
Opinions from users & sellers: http://forums.corvetteforum.com/off-topic/2834259-dayco-timing-belts-any-good-or-avoid.html
mattdavis11 12-08-2013 05:33 AM
I know the gates timing belt I bought doesn't work. I'll send it to anyone who wants it. I stick with contitech.
flash968 12-08-2013 06:19 AM
why do you think it doesn't work? that would be a first that i have heard
no mechanic i know will install a contitech without you signing a release or waiving their responsibility. those things are like rubber bands.
dayco designed one belt and gates designed the other. they were the original suppliers. contitech only came in when porsche shopped for a cheaper supplier. they have since switched back.
CHICKS 12-08-2013 06:39 AM
You're fine with the dayco, but if you can't sleep at night buy a gates from amazon for $14 shipped. The Kevlar belt is probably the biggest waste of money. I wouldn't buy a conti belt. They seem to be going the way of Bosch.
kwikt 911 12-08-2013 06:57 AM
That's the way I was thinking, I just wanted to be reassured.
CHICKS 12-08-2013 09:50 AM
We're here for you.
mattdavis11 12-08-2013 01:31 PM
Originally Posted by flash968 (Post 7795648)
why do you think it doesn't work? that would be a first that i have heard.
The teeth don't mesh with the cam and crank. If you want it, let me know.
flash968 12-08-2013 01:55 PM
very odd. never heard that before. i wonder if it's somehow the wrong belt?
probably wouldn't work on a 968, so i can't use it. thanks though
CHICKS 12-08-2013 03:07 PM
What's the belt number Matt?
944tothefloor 12-08-2013 05:50 PM
I've heard of the teeth not meshing thing. If you have the right belt, you sometimes have to really wiggle the belts on. Sometimes when your'e putting it on, one side is a tighter tension than the other side, so it seems off. Carefully warming it in the sun does help. Or maybe it actually is a bad belt...
mattdavis11 12-09-2013 08:37 AM
I don't know what the numbers mean but the info below is exactly how the belt reads:
107 DO NOT CRIMP 09110 530282438
Made In USA
Here's a picture of the teeth not cutting the mustard.
http://forums.pelicanparts.com/uploa...1386610298.jpg
It's free to good home if you want it. Only attempted to be installed once, otherwise brand spanking new.
mattdavis11 12-09-2013 09:12 AM
This is a used timing belt, still in good condition. It's a Contitech belt. See how well it fits?
http://forums.pelicanparts.com/uploa...1386611948.jpg
I have no doubt advancements have been made, but under my watch, a contitech cam belt has never failed. Unless I have the wrong belt, I'm not going waste another $10 on gates.
rhett 12-09-2013 10:34 AM
Made In USA
Info from the Gates website confirms that the 107 is a belt for the 8V 944...so, I guess the one you got is marked up wrong or very badly made!
http://forums.pelicanparts.com/uploa...1386617625.jpg
9FF 12-09-2013 10:52 AM
I will never use Conti after the teeth stripped on a new belt correctly installed after 12k miles. Happened a few years ago, this was my post on RL with the outcome: Rennlist Discussion Forums - View Single Post - Another Timing Belt Failure - But All is Well
mattdavis11 12-09-2013 11:40 AM
I have had issues with contitech, but only on the balance belt. Once lost all but 9 teeth on one side, but I blame that on a P9201, which was calibrated correctly. I did let a Porsche tech tension the belt, but I was right there the whole time, from bar calibration on the 9201 to cover install. My hands only from now on.
Good luck.
944tothefloor 12-09-2013 10:37 PM
Good luck.
Duly noted, and unfortunately the belt legend continues.
flash968 12-10-2013 06:14 AM
it looks to me from the pic that the belt just isn't seated down into the teeth. it matches up great for a while, then it pulls away, but it looks like it's long before it should be forcing itself up and out of the teeth
MB968 12-10-2013 07:56 AM
I'd definitely not use that belt. I've never seen a toothed belt that didn't fit out of the box. That goes for both automotive and on machinery where they are used for high torque applications. Sometime you have to work them in place if the fit is really good. But if your pic conveys it correctly, it doesn't look as thought that belt has a chance of having the right pitch. I'd take it back to the supplier to have them compare it to another belt. Or even better, call Gates. Their quality guys will want to see it so they can figure out what went wrong in manufacturing. My guess is either they had a bad run of belts with the pitch set incorrectly (highly unlikely), or they were marked wrong. No way the belt should be that far off.
flash968 12-10-2013 10:12 AM
maybe i'm just not seeing what you are. it doesn't look to me to be off, and certainly not far. the belt has no tension on it. i'd like to see it with some tension on it. i have a feeling it would fall into place.
i could be wrong though. hard to tell from the pic
Gawernator 12-10-2013 11:55 AM
I'd call them about this
mattdavis11 12-10-2013 03:47 PM
That belt has some tension on it. Both do, I wrapped both around the cam gear and lightly pinched it with vice grips to illustrate how the teeth spacing is too narrow to fit in the gear.
There's no way it will work. It had me scratching my head too when I tried to put it on the car. Since I had 3 other used cam belts, I did a comparison to the others and it's definitely not right. The length is right, but the teeth are out of whack.
Cam belts are cheap, if it was a balance belt, I'd call the supplier.
gtgt__bangbang 06-12-2014 09:35 PM
bought a dealer / Porsche belt a few years ago, when I got the substantial & official looking box, the belt in there simply 'felt' better than the after market belt (sorry, dont recall who's) I had gotten first and still had in hand. Seemed 'stiffer' , maybe heavier(?) than the aftermarket
I went with the factory belt based on feel and paranoia.
Now time to fresh up the belt (6/14) I ordered another Porsche belt, again just over $100, (a wee cheaper than last go , from another online OEM vendor). The box was quite different, very plain cardboard. The belt inside was marked PORSCHE and ISORAN DAYCO, Made in Italy, along with some other #s (see pix). Cant say as the "feel" that was so convincing last time, so no opinion.
Another difference notable from some pix on this thread is the new Porsche / Dayco belt (also the belt I removed, the known old-school factory) has a small groove at the crown of the teeth.
I imagine the groove is either a flex enhancer, or more likely a noise abatement design.
http://forums.pelicanparts.com/uploa...1402637598.jpg
John_AZ 06-13-2014 05:05 AM
Thanks. Nice and clear picture.
It is interesting about the groove at the crown of the belt.
J_AZ
flash968 06-13-2014 06:45 AM
more than likely that groove allows the teeth get more traction.
Lapkritis 06-13-2014 08:19 AM
Made In USA
Interesting - would be worth while to get a tooth count on this relative to the good belt. I might estimate this one is 2-3 teeth fewer.
sausagehacker 06-13-2014 12:15 PM
I have a Contitech belt on my car... now you guys have me worried...
Lapkritis 06-13-2014 12:40 PM
Contitech does fine belts. They have a 12mos warranty as well; it's the most popular belt for service on VW/Audi as OEM equivalent and there are millions of those cars out there.
ernie9944 06-13-2014 12:42 PM
Don't loose any sleep about having Contitech belt on you car I had them for the last 30 years and not once did I had to sign any release lol to both mechanics which work on my car either the 944 or 968 and not once did any of those belts fail.I once install a Dayco on my 944 and two days later I threw it in the garbage because of issues with it.:D
gtgt__bangbang 06-14-2014 05:59 AM
I have my doubts about "traction" fwiw.
If you think about how a drive belt functions - pulling the gear along via contact between the SIDE of the belt tooth to the SIDE of the gear, (and recall chain/belt wear never at the nadirs or peaks, but on tooth sides), then the peak of the tooth transfers only a tiny tiny fraction of the force.
nope , I bet some bright young intern discovered that the noise contribution of the millions of little 'pops' of air, forced out when the belt nub slaps into the pulley groove could be mitigated providing an escape path, and the least detrimental place to locate the groove ( missing material, after all) was at the tooth peak which does little work to begin with.
The added flexibility of the belt due to tiny grooves at the top of the stiffest part of the belt ( ie the tooth, as opposed to the valley ) is probably negligible.
Now back to the counting angels dancing on pinheads.
flash968 06-14-2014 06:45 AM
every single belt failure i have seen or heard of on the 968 has been a contitech. i know of no failures reported with gates. gates and dayco were the original designers of the system for the 944 and the 968.
no mechanic i know will use contitech, at least not without voiding their warranty. they all refuse, with many referring to them as "rubber bands".
grooves provide traction. in this case they may well allow the belt tooth to compress a bit more under tension, spread out, and provide more contact on the gear. this may not have much of an effect when the belt is new, but as it ages and hardens, it may well provide better contact.
gtgt__bangbang 06-14-2014 07:41 AM
I put pixs above in thread, but I was feeling generous and sprung the couple extra $10s for a factory Porsche cam belt for my 3L.
I received a factory boxed belt inked up with 'Porsche' and 'Dayco Isoran', FWIW.
Damn did veedub switch all spares to 'lowest bidder'?
I put a Contitech belt on the less critical balance shafts, as it was cheap nuf and local.
Don't forget to roll the engine back 10 degrees before TDC to make the cam belt tension measurement ! I was missing a page of my old print from clarks garage and almost missed that yikes
Is it just me or is the balance belt annoyingly loose on the long run? I know the belt is just driving two freely turning shafts, but I cant see how that long belt run does not slap at the water pump pulley . PS I tensioned belt with a 9201
ernie9944 06-14-2014 08:59 AM
[QUOTE=flash968;8115864]every single belt failure i have seen or heard of on the 968 has been a contitech. i know of no failures reported with gates. gates and dayco were the original designers of the system for the 944 and the 968.
YES YES YES,more belt failure with Contitech.We have heard that one before but I,m sure your taking into account number of Contitech belts versus Gates or Dayco install on 924/944/968 in your research.:D
flash968 06-14-2014 09:23 AM
it's not research. it's just from watching and reading for the last 11 years. many versus zero. i'll go with zero, and let the others who want to run an unnecessary risk pay the $5k for the crashed valves when their contitech fails. just common sense.
88Silver924S 06-14-2014 02:31 PM
For what it's worth
I have owned my car since new and it came from Porsche with a Uniroyal timing belt. Uniroyal was bought out by Gates. I have my old timing belts hanging in the garage and the OEM Uniroyal and the 2nd belt which was a Gates look identical in design and markings down to the marking fonts.
From the Dayco web site:
Automotive Click the training tab and enjoy some marketing videos including one on the "W profile belt" about the groove on the tooth noted by 'gtgt_bangbang' (I know the video is about serpentine belts not cog/timing belts). The "W" is for misaligned or worn pulleys on their serpentine belts, I don't know about the W-profile on the teeth of a timing belt.
And as to belt construction material changes through the years (and our cars are from the 1980's) I gather that the original belts were neoprene and the newer belts are EPDM or HSN (can we assume this is true of timing belts?):
"Until the late 1990s and early 2000s, neoprene, the original rubber compound developed into serpentine belts, was the primary material in all belts, both original equipment and aftermarket products. While neoprene was, and still is, a good material for misalignment chirp noise, its flex fatigue characteristics are marginal, especially in hot and cold conditions that roll around yearly. In early 2000, due to advancements in belt technology to achieve better performance under those extreme winter and summer temperature conditions, and to get more mileage out of the belt, EPDM became the material of choice for all major belt suppliers." (from Dayco's "Why Belt Dressing Is Not A Solution . .)
For my car: 95107. From the Gates web site: T107 is "HCR (Hi Temp Neoprene)" where their blue belt T107RB is "HSN (Highly Saturated Nitrile)". I can't find what material the Dayco's are made of.
flash968 06-14-2014 03:54 PM
not sure what they were made of, but porsche originally supplied gates and dayco for this system. then they switched to contitech. after a couple of years with multiple failure reports of the contitech, they switched back to gates and dayco.
the issue with contitech is indeed fatigue due to heating and cooling. they just don't hold up as long, and begin to stretch. many people don't realize this though, as they fail to retension their belts every year, as the owner's manual tells them they should (the 968 only requires this on the balance belt due to having a hydraulic tensioner on the timing belt). so, they wait until the belt change, and figure that if they didn't snap, they must have been fine. dangerous assumption. had they retensioned the belt(s) on schedule, they would generally find that the contitech required it more than the gates.
mattdavis11 06-15-2014 03:54 AM
What it boils down to is, any idiot that owns a 944/951/968 should know there is a heavy premium on camshaft belt failure, should it occur. I have a free belt, a Gates belt, pictures are in this thread, take me up on the offer, please. I want to know how your car fares with that belt. I'll stick with Contitech. A used Contitech at that, over Gates.
