Is this supposed to attach to something or not?
My '87 924S ( like 944 ) pictured below is my DME unit , the harness and my stray circled in red, "Plug connection for speed sensor" ..but cannot find anyplace to plug it in to . Is this just for diagnosis or is mine unplugged?
Thanks Austin
1988 Porsche 924S - On the road again after 3+ years.
Dodge GC ES 278,xxx and counting.
Old 02-14-2014, 12:47 PM
bump
Old 02-14-2014, 07:43 PM
sketchers356's Avatar
Why not post this in the 924/944 forum rather than the turbo one? You will get more hits.
Alexander
'75 911S Targa
'86 951 SOLD
Old 02-17-2014, 08:58 PM
Straight shooter
Lapkritis's Avatar
Just took my '84 apart awhile ago. Noted the pigtail on the engine harness near the pedals and the other end up behind the instruments. Look up behind the speedo from the pedal area.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-22-2014, 07:26 AM
easydave
dave1192's Avatar
That goes to the Tach on my 944 -- Tach wasn't working when I bought the car. Found this 2 pin plug disconnected. plugged it in and presto -- tach has worked ever since.
Easy Dave
Old 02-22-2014, 08:05 AM
Does this branch off the loom close to the DME ? I took a quick look at mine and only saw two ,2 wire connectors close to DME. My dash is off but all connectors are connected to track down an intermitant fault. Let me know how far from DME and if it branches off the main loom to DME and I'll take a better look. This is from early 87 ;I have a complete harness on the floor from a late 87 and it has some differences
Old 02-22-2014, 10:00 AM
Volhv's Avatar
Pretty sure it's where the "coding adapter" or "impedance adapter" plugs into.
Four DMEs in One Box - www.Motronic.ws** ©2007** ©2011 FR Wilk
Canada and US (minus California) don't have them and are left blank as you found it.
Hey neighbor (maint), where is your car from originally?
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 02-22-2014, 05:51 PM
It has been in BC since 1993, before that I don't know. It is US spec (just looked it up). That explains some of the wiring differences from the parts car.
Old 02-23-2014, 01:04 AM
