rough running until 3, 000 rpm
My 944 (1986 - non turbo) has been running very rough lately
It starts well but runs terrible when it is cold and under 3, 000 rpm. It really runs like on 3 cylinders, no power at all. When the engine is hot it is better but still not full power under 3, 000 rpm.
I have no idea where to start looking ? Bad injector ? Fuel pump (the fuel pump is new) DME ?
Any help would be appreciated
Old 03-09-2014, 01:18 PM
fiat22turbo's Avatar
I would check the injectors to ensure you don't have one stuck open slightly. Verify proper fuel pressure, in case you have a regulator issue. Double check the ignition components (plugs, wires, cap/rotor). Also vacuum leaks can cause weird issues and don't forget the lines that run under the intake.
Old 03-09-2014, 01:42 PM
easydave
dave1192's Avatar
Check for vacuum leaks EVERYWHERE!
Easy Dave
Old 03-09-2014, 02:49 PM
plays with toy cars
sausagehacker's Avatar
Although a vacuum leak or something is a lot more likely, inspect the AFM and test it to make sure the inner resistor track is working smoothly.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 03-09-2014, 05:41 PM
Thank you for the replies. It is very helpful !
Old 03-09-2014, 07:29 PM
My guess would be the DME temp sensor.
It's easy to measure, as you don't need to dissasemble too much.
Sensors and Gauges - Information, Troubleshooting, and Testing
but really, anything mentioned before is a good guess!
Old 03-10-2014, 01:12 AM
