dumb question : running w/o transmission
is it stupid to run the engine without the transmission installed?
I imagine removing all that resistance to the drive shaft could lead to excess rotation.
87 944 NA |
Not a problem, just don't expect to get anywhere very fast.
-John '94 968 Iris Blue '85.5 944 White - Rally Cross and wrenching practice '84 944 Gemini Grey (gone, but missed...) |
lol - won't matter. you won't be going anywhere without the trans
seriously though, engine dynos don't use transmissions, and they spin those suckers up all day long |
The flywheel attached to the engine controls how quickly the engine spins. Without the transaxle, the engine is spinning just like it is in neutral.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
The torque tube might walk. I would not do much of this.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
If it is short durationy, you could always disconnect the torque tube to the engine by pushing down on the clutch.
Is very busy
If you had just an engine but no transmission and drivetrain, you'd need to push your car even though the engine runs
If you have an engine and a drivetrain, but no transmission, you wouldn't have enough torque to move sufficiently since the drivetrain wouldn't be geared down. On the bright side, without the transmission, your car would weigh less
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
