GreenWater's Avatar
Yep, that color is what Porsche calls "Light Gray" But it's really more of a tan/beige. I call that color greige. It's a very common color from 85.5-87.
Wow, I don't think I have seen "light gray" script seats. That's awesome and it looks like they are in good shape too. Very cool.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 04-16-2020, 10:12 AM
mine is 1984 , all interior is brown
code on sticker says LU
i dont know is it original or not
Old 04-16-2020, 06:01 PM
GreenWater's Avatar
Yep, LU is Brown.
84 944
Old 04-17-2020, 08:08 AM
Antipurist
Kwazii's Avatar
Thanks! Surprisingly, the seats are about the only thing in decent condition on this car! I originally wanted to convert the interior to all black (real) leather but this colorway has really grown on me, especially the full script seats which don't seem that common.
So if anyone has a light grey carpet set for sale, let me know
Old 04-20-2020, 08:40 AM
Is the information solely under the carpet or is there anything relevant on the spec sheet that has been next to my tool kit for over 30 years!
1987 944 Summer
2006 E90 Winter
Old 04-22-2020, 02:40 PM
Wasn't sure if you had gotten this one or not, but here's mine:
1987 944 Turbo
Listed as "Burgundy" on the original window sticker, color code in the trunk is YZ.
Old 04-24-2020, 09:04 PM
Here's my 87 924S's options decal.
Guards Red Exterior (not my fave) with Linen/Brown Vinyl/Script seats, dark brown dash and door top trims.
I'll ask the question in a separate thred, but if anyone has researched the best interior paint match for the dark brown dash, I'd be grateful for any results.
cheers, John
Old 04-26-2020, 08:38 AM
Ernie944's Avatar
My ex 83 -944 had a beige ...brown interior code 3ff.
Speakers install in the rear wheels wells.
Caraquet,N.B. Canada.
Old 04-26-2020, 08:35 PM
Making interior color code list is very good idea. I was already searching but couldn't get any good results. Thanks for discussing and sharing this topic.
Old 05-03-2020, 11:00 AM
Does anybody has seen CB as interior code? It is on the sticker of mine P924S from 1986.
Regards Govert
Old 05-17-2020, 08:34 AM
cheers, John
My go to for leather dye and other leather products is Colorplus.com, out of Pennsylvania. Their Surflex product is easy to use (water based), easy to clean up, and they have a color matching service that has worked perfectly every time for me (over 30 years as a satisfied customer.) All you need to do is send a one inch square color swatch (should come from an area that is not faded or dirty.) Very reasonable cost for such a service.
Just don't apply it too thick, several light coats will look much better than one thick coat.
Good luck, George Beuselinck
Old 05-17-2020, 10:22 AM
Thanks George, at this, having spent a nutty amount of time on it, removing most of the vinyl and building it uper, shaping and surfacing (60 HRS +), my dash is now in epoxy primer; next I plan on applying SEM Texture Coat, then their Color Coat, custom mixed at a local paint jobber. It won't he stock (no faux-leather grain) and it won't be perfect-perfect (recreating details in filler is tough) but it should be OK. Famous last words. Thanks very much, John
Old 05-17-2020, 03:05 PM
I just realized some about my interior: it’s Linen and Black, not Linen and Very Dark Brown. John
Old 05-18-2020, 04:30 PM
Ernie944's Avatar
Anybody knows the interior code for the 944 Turbo Silver Rose?
TIA
Old 05-18-2020, 06:34 PM
Regards Govert
Govert, did you ever find out what this code is? I too have a 924S with the CB interior. Unfortunately, my seats have been badly covered in a non-Porsche cloth and I now want to find the correct colours and get the seats done properly. The only thing i know for certain is that the cream carpet and black door cards/dash are original, is this the same with yours?
Old 09-12-2021, 07:42 AM
Further to the above a little more digging suggests that the colour options were per the attached and tracked across horizontally, does anyone know if this is correct? I.e. the light-grey carpet means that light-grey seats in one of the described combinations was a prerequisite.
Old 09-23-2021, 09:20 AM
I have an 87 924S in the common Porsche Light Grey or Greige “XP” .. seats are Porsche Script, Drivers isn’t in great order ... I came across these Sports Seats from a 944 of same era & hoping, even though they are a different design, that they’ll look OK once fitted .. color seems correct :
Old 01-27-2022, 04:52 PM
If this is still of interest: My 11-'85 924S has interior code 'AB', is Alpineweiss (L90E) and this is the seat combo: black vynal sides and porsche script cloth center in some sort of purple? (maroon?)
Old 11-26-2025, 09:46 AM
GreenWater's Avatar
Yep, we are still interested in interior color code, thanks. I am still compiling a list of the color code/seat options and this is helpful.
I have seen the color code AB once before and the seats were black with black script inserts. So I would assume that your script material used to be black when it was new and has just faded over the years. I could be wrong, but I don't think they ever made purple script material.
84 944
Old 11-26-2025, 02:02 PM
Well, the car was 37 years with the previous owner and I am pretty sure he did not swap interiors. Rear seats have the same fabric, but also some weather damp on them atm as the car stood outside for a long time.
Maybe its a European spec only? or an option? I am not good with the option codes, but maybe someone is?
Here are some more pics of the tag and interior. Its difficult to get good color in LED inside lighting though..
Edit: I think you are right though: someone else also stated that color was not delivered and must have been the influence of UV!
Old 11-30-2025, 03:34 AM
