I suggest you remove the weights from the lips and have them re-applied on the rear (using either the tape on weight or clamp or, but I prefer tape on). Water sits between the weights and lips and eventually the clear starts to crack/spider web and you'll need to get them refinished.
Try getting the centers in refinished in gold, you might change your mind about running them. |
But 1st, water pump, timing belt, front seals, oil change, trans oil change, new rad hoses. Car puked up antifreeze in the garage this past week...fun times. |
| All times are GMT -8. The time now is 05:39 PM. |
