want to fix power steering return cooler line for last time
Want to fix my power steering cooler-to-reservoir hose for the last time, and not worry about it again.
Power steering cooler tube (the moonshiner maze) is 10 mm OD , mild steel.
Power steering reservoir inlet is 12 mm od. Mismatch. Naturally.
Originally there was a hose crimped to outlet end of cooler tube to run up to reservoir; original hose long gone but per PET looks like one of those specials; soft hose 10mm ID one end, flared to 12mm ID other side. But wait ! Theres More ! The hose is not offered as a separate item, only available with the cooler, for $$$.
Thank you Porsche for making life complicated for us loyal but Poorsche owners.
I previously had a 10mm line crimped onto cooler line, intending to try to force the other end onto the 12mm reservior stub, but with only high pressure hose (stiff stuff) available, no way will it expand that much.
At this point I am looking for a 10mm ID / 12mm(ish) OD "butt weld union" that will let me braze to cooler tube, still terminating in a compression (crimped ferrule fitting) flared tip.
The idea not unlike this wrong-size item ; Tube Butt Weld Fittings - Swagelok</a><br /> <br /> <br /> Have not found anything yet . I nearly sure there is suitable dimension plain steel tube out there; 10mm ID , 12mm OD. This would make a very simple transition to 12mm hose, but tube would lack any shoulder to secure the crimped hose. I dont even know the name of the slight 'flare' end that accommodates a crimp on fitting - anyone ? its not quite a flare, I ahve no way of forming that shape in steel.<br /> <br /> Will be sadly scrounging the generic brake line bin at O'Rs, then probably to the hydraulic shop in town come Monday, meanwhile posing a few ideas & questions for the brilliant pelican flock here;<br /> <br /> <br /> 1) hate to solve old problems; is there a better fix already out there? has any one found a 10mm to 12mm hydraulic line (useable length , suitable for low pressure hot oil) that I can simply have crimped onto cooler tube? searchable particulars please …. attaboy richly deserved will come back your way.<br /> <br /> barring that golden solution;<br /> <br /> 2) any one have a part name, number etc, for the braze-on fitting (10mm ID , 12mm OD, some kind of swage or mild flare on the end that allows for a secure & oil tight crimp hose fitting on the 12mm end ? )<br /> <br /> <br /> pics shows the starting point of tube; I already slit the crimped ferrule, and I intend to cut off the one end of steel tube and repair with the yet-to-be-discovered fitting. Other criteria; cheap, secure, leak tight and quickly available.<br /> <br /> thanks in advance, will post a how to do guide after putting this to rest.<br /> <br /> <br /> <br /> <br /> Now now quit smirking; when I got my car, the fuel lines, underframe, were pretty well crushed by DP parking the car atop a rock; I removed those loooong gas lines under car, cut out the offending sections, and brazed on some mild steel tube to replace the section. Worked great and no complaints since. (was a propane + ox braze ... nothing more. Happy to try MAPP this time) </div> <!-- / message --> <!-- GUEST --> <br> <!-- Pelican Ad START --> <div class="pelicanadplacement" data-placementid="32"></div> <!-- Pelican Ad END --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --> <!-- END TEMPLATE: ad_showthread_firstpost_sig --> </td> </tr> <tr> <td class="alt2" style="font-weight:normal; border: 1px solid #FFFFFF; border-right: 0px"> <!-- status icon and date --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/post_old.gif" alt="Old" border="0" /> <font class="smallfont"> 06-21-2014, 03:48 PM </font> <!-- / status icon and date --> </td> <td class="alt1" style="background-color: #E8E8E8"> <table cellspacing=0 cellpadding=0 border=0 width=100%> <tr> <td align=left style="border: 0px solid; border-top: 0px">   </td> <td align=right> <!-- Tech Article Directory Link --> <!-- Old <img border="0" src="https://www.pelicanparts.com/graphics/tech-article-directory-forum.png" width="15" height="15"> --> <!-- Old <a style="color: #000080; font-size: 10pt" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Pelican Parts Technical Article Directory</a>    --> <span style="color: #9C9C9C; font-size: 11px;"><a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/" target="_blank">Pelican Parts Catalog</a> | <a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Tech Articles</a> | <a style="color: #45558A; font-size: 11px" href="https://www.pelicanparts.com/promos/" target="_blank">Promos & Specials</a>   </span> <!-- controls --> <a href="https://forums.pelicanparts.com/newreply.php?do=newreply&p=8128251" rel="nofollow"><img src="https://forums.pelicanparts.com/images/buttons/quote.gif" alt="Reply With Quote" border="0" /></a> <!-- / controls --> #<a href="https://forums.pelicanparts.com/8128251-post1.html" target="new" id="postcount8128251" name="1"><strong>1</strong></a> (<b><a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html#post8128251" title="Link to this Post">permalink</a></b>) </td> </tr> </table> </td> </tr> </table> <!-- post 8128251 popup menu --> <!-- / post 8128251 popup menu --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- BEGIN TEMPLATE: spacer_close --> </div> </div> </div> <!-- / close content container --> <!-- END TEMPLATE: spacer_close --> <!-- / post #8128251 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: ad_showthread_firstpost --> <!-- END TEMPLATE: ad_showthread_firstpost --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #8128253 --> <!-- BEGIN TEMPLATE: spacer_open --> <!-- open content container --> <div align="center"> <div class="page" style="width:98%; text-align:left"> <div style="padding:0px 0px 0px 0px" align="left"> <!-- END TEMPLATE: spacer_open --> <div id="edit8128253" style="padding:0px 0px 6px 0px"> <!-- this is not the last post shown on the page --> <!-- BEGIN TEMPLATE: postbit_legacy --> <table id="post8128253" class="tborder" cellpadding="6" cellspacing="1" border="0" width="100%" align="center"> <tr valign="top"> <td class="alt2" width="175" style="border: 1px solid #FFFFFF; border-top: 0px; border-bottom: 0px" > <div id="postmenu_8128253"> <table width=100% cellpadding=0 cellspacing=0 border=0> <tr> <td align=left><a rel="nofollow" name="post8128253" class="bigusername" href="https://forums.pelicanparts.com/members/194350.html">gtgt__bangbang</a></td> <td align=right><!-- BEGIN TEMPLATE: postbit_onlinestatus --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/user_offline.gif" alt="gtgt__bangbang is offline" border="0" /> <!-- END TEMPLATE: postbit_onlinestatus --></td> </tr> </table> </div> <div class="smallfont">Registered User</div> <div class="smallfont">  <br /> <div>Join Date: Jun 2014</div> <div> Posts: 124 </div> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --> <div> </div> </div> </td> <td class="alt1" id="td_post_8128253" style="border-right: 1px solid #FFFFFF"> <!-- message --> <div id="post_message_8128253"> Want to fix my power steering cooler-to-reservoir hose for the <i>last</i> time, and not worry about it again.<br /> <br /> Power steering cooler tube (the moonshiner maze) is 10 mm OD , mild steel. <br /> Power steering reservoir inlet is 12 mm od. Mismatch. Naturally.<br /> <br /> Originally there was a hose crimped to outlet end of cooler tube to run up to reservoir; original hose long gone but per PET looks like one of those specials; soft hose 10mm ID one end, flared to 12mm other side, The hose is not a separate item from the cooler, only available for $$$. <br /> <br /> Thank you Porsche for making life complicated for us loyal but Poorsche owners! <br /> <br /> I previously had a 10mm line crimped onto cooler line, intending to try to force the other end onto the 12mm reservior stub, but with only high pressure hose available, no way will it expand that much.<br /> <br /> At this point I am looking for a 10mm ID / 12mm(ish) OD "butt weld union" that will let me braze to cooler tube, still terminating in a compression (crimped ferrule fitting) flared tip.<br /> <br /> The idea not unlike this swagelok.com/search/find_products_home.aspx?SEARCH=/search/Tube+Butt+Weld+Fittings/id-10002063/type-1&item=18aa84da-1ad8-463c-9be0-64a4a8da74af<br /> <br /> <br /> Have not found anything yet . I am almost sure there is suitable plain steel tube out there; 10mm ID , 12mm OD, that would make a simple transition, but lacking any shoulder to secure the crimped hose.<br /> <br /> Will be sadly scrounging the generic brake line bin at O'Rs, then probably to the hydraulic shop in town come Monday, so posing a few ideas & questions for the brilliant pelican flock here;<br /> <br /> <br /> 1) hate to solve old problems; is there a better fix already out there? has any one found a 10mm to 12mm hydraulic line ( suitable for low pressure hot oil) that I can simply have crimped onto cooler? searchable particulars please …. attaboy will come back your way.<br /> <br /> barring that<br /> <br /> 2) any one have a part name, number etc, for the braze-on fitting I want (10mm ID , 12mm OD, some kind of swage or mild flare on the end that allows for a secure & oil tight crimp hose fitting on the 12mm end ?<br /> <br /> <br /> <br /> Now now quit smirking; when I got my car, the fuel lines, underframe, were pretty well crushed by DP parking the car atop a rock; I removed those loooong gas lines under car, cut out the offending sections, and brazed on some mild steel tube to replace the section. Worked great and no complaints since. (that was a propane + ox braze ... nothing more. Happy to try MAPP this time) </div> <!-- / message --> <!-- GUEST --> </td> </tr> <tr> <td class="alt2" style="font-weight:normal; border: 1px solid #FFFFFF; border-right: 0px"> <!-- status icon and date --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/post_old.gif" alt="Old" border="0" /> <font class="smallfont"> 06-21-2014, 03:50 PM </font> <!-- / status icon and date --> </td> <td class="alt1" style="background-color: #E8E8E8"> <table cellspacing=0 cellpadding=0 border=0 width=100%> <tr> <td align=left style="border: 0px solid; border-top: 0px">   </td> <td align=right> <!-- Tech Article Directory Link --> <!-- Old <img border="0" src="https://www.pelicanparts.com/graphics/tech-article-directory-forum.png" width="15" height="15"> --> <!-- Old <a style="color: #000080; font-size: 10pt" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Pelican Parts Technical Article Directory</a>    --> <span style="color: #9C9C9C; font-size: 11px;"><a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/" target="_blank">Pelican Parts Catalog</a> | <a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Tech Articles</a> | <a style="color: #45558A; font-size: 11px" href="https://www.pelicanparts.com/promos/" target="_blank">Promos & Specials</a>   </span> <!-- controls --> <a href="https://forums.pelicanparts.com/newreply.php?do=newreply&p=8128253" rel="nofollow"><img src="https://forums.pelicanparts.com/images/buttons/quote.gif" alt="Reply With Quote" border="0" /></a> <!-- / controls --> #<a href="https://forums.pelicanparts.com/8128253-post2.html" target="new" id="postcount8128253" name="2"><strong>2</strong></a> (<b><a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html#post8128253" title="Link to this Post">permalink</a></b>) </td> </tr> </table> </td> </tr> </table> <!-- post 8128253 popup menu --> <!-- / post 8128253 popup menu --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- BEGIN TEMPLATE: spacer_close --> </div> </div> </div> <!-- / close content container --> <!-- END TEMPLATE: spacer_close --> <!-- / post #8128253 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #8128255 --> <!-- BEGIN TEMPLATE: spacer_open --> <!-- open content container --> <div align="center"> <div class="page" style="width:98%; text-align:left"> <div style="padding:0px 0px 0px 0px" align="left"> <!-- END TEMPLATE: spacer_open --> <div id="edit8128255" style="padding:0px 0px 6px 0px"> <!-- this is not the last post shown on the page --> <!-- BEGIN TEMPLATE: postbit_legacy --> <table id="post8128255" class="tborder" cellpadding="6" cellspacing="1" border="0" width="100%" align="center"> <tr valign="top"> <td class="alt2" width="175" style="border: 1px solid #FFFFFF; border-top: 0px; border-bottom: 0px" > <div id="postmenu_8128255"> <table width=100% cellpadding=0 cellspacing=0 border=0> <tr> <td align=left><a rel="nofollow" name="post8128255" class="bigusername" href="https://forums.pelicanparts.com/members/194350.html">gtgt__bangbang</a></td> <td align=right><!-- BEGIN TEMPLATE: postbit_onlinestatus --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/user_offline.gif" alt="gtgt__bangbang is offline" border="0" /> <!-- END TEMPLATE: postbit_onlinestatus --></td> </tr> </table> </div> <div class="smallfont">Registered User</div> <div class="smallfont">  <br /> <div>Join Date: Jun 2014</div> <div> Posts: 124 </div> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --> <div> </div> </div> </td> <td class="alt1" id="td_post_8128255" style="border-right: 1px solid #FFFFFF"> <!-- message --> <div id="post_message_8128255"> Want to fix my power steering cooler-to-reservoir hose for the <i>last</i> time, and not worry about it again.<br /> <br /> Power steering cooler tube (the moonshiner maze) is 10 mm OD , mild steel. <br /> Power steering reservoir inlet is 12 mm od. Mismatch. Naturally.<br /> <br /> Originally there was a hose crimped to outlet end of cooler tube to run up to reservoir; original hose long gone but per PET looks like one of those specials; soft hose 10mm ID one end, flared to 12mm other side, The hose is not a separate item from the cooler, only available for $$$. <br /> <br /> Thank you Porsche for making life complicated for us loyal but Poorsche owners! <br /> <br /> I previously had a 10mm line crimped onto cooler line, intending to try to force the other end onto the 12mm reservior stub, but with only high pressure hose available, no way will it expand that much.<br /> <br /> At this point I am looking for a 10mm ID / 12mm(ish) OD "butt weld union" that will let me braze to cooler tube, still terminating in a compression (crimped ferrule fitting) flared tip.<br /> <br /> The idea not unlike this (damn ... link prohibited?)<br /> <br /> Have not found anything yet . I am almost sure there is suitable plain steel tube out there; 10mm ID , 12mm OD, that would make a simple transition, but lacking any shoulder to secure the crimped hose.<br /> <br /> Will be sadly scrounging the generic brake line bin at O'Rs, then probably to the hydraulic shop in town come Monday, so posing a few ideas & questions for the brilliant pelican flock here;<br /> <br /> <br /> 1) hate to solve old problems; is there a better fix already out there? has any one found a 10mm to 12mm hydraulic line ( suitable for low pressure hot oil) that I can simply have crimped onto cooler? searchable particulars please …. attaboy will come back your way.<br /> <br /> barring that<br /> <br /> 2) any one have a part name, number etc, for the braze-on fitting I want (10mm ID , 12mm OD, some kind of swage or mild flare on the end that allows for a secure & oil tight crimp hose fitting on the 12mm end ?<br /> <br /> <br /> <br /> Now now quit smirking; when I got my car, the fuel lines, underframe, were pretty well crushed by DP parking the car atop a rock; I removed those loooong gas lines under car, cut out the offending sections, and brazed on some mild steel tube to replace the section. Worked great and no complaints since. (was a propane + ox braze ... nothing more. Happy to try MAPP this time) </div> <!-- / message --> <!-- GUEST --> </td> </tr> <tr> <td class="alt2" style="font-weight:normal; border: 1px solid #FFFFFF; border-right: 0px"> <!-- status icon and date --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/post_old.gif" alt="Old" border="0" /> <font class="smallfont"> 06-21-2014, 03:52 PM </font> <!-- / status icon and date --> </td> <td class="alt1" style="background-color: #E8E8E8"> <table cellspacing=0 cellpadding=0 border=0 width=100%> <tr> <td align=left style="border: 0px solid; border-top: 0px">   </td> <td align=right> <!-- Tech Article Directory Link --> <!-- Old <img border="0" src="https://www.pelicanparts.com/graphics/tech-article-directory-forum.png" width="15" height="15"> --> <!-- Old <a style="color: #000080; font-size: 10pt" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Pelican Parts Technical Article Directory</a>    --> <span style="color: #9C9C9C; font-size: 11px;"><a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/" target="_blank">Pelican Parts Catalog</a> | <a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Tech Articles</a> | <a style="color: #45558A; font-size: 11px" href="https://www.pelicanparts.com/promos/" target="_blank">Promos & Specials</a>   </span> <!-- controls --> <a href="https://forums.pelicanparts.com/newreply.php?do=newreply&p=8128255" rel="nofollow"><img src="https://forums.pelicanparts.com/images/buttons/quote.gif" alt="Reply With Quote" border="0" /></a> <!-- / controls --> #<a href="https://forums.pelicanparts.com/8128255-post3.html" target="new" id="postcount8128255" name="3"><strong>3</strong></a> (<b><a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html#post8128255" title="Link to this Post">permalink</a></b>) </td> </tr> </table> </td> </tr> </table> <!-- post 8128255 popup menu --> <!-- / post 8128255 popup menu --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- BEGIN TEMPLATE: spacer_close --> </div> </div> </div> <!-- / close content container --> <!-- END TEMPLATE: spacer_close --> <!-- / post #8128255 --> <!-- END TEMPLATE: postbit_wrapper --><!-- BEGIN TEMPLATE: postbit_wrapper --> <!-- post #8128370 --> <!-- BEGIN TEMPLATE: spacer_open --> <!-- open content container --> <div align="center"> <div class="page" style="width:98%; text-align:left"> <div style="padding:0px 0px 0px 0px" align="left"> <!-- END TEMPLATE: spacer_open --> <div id="edit8128370" style="padding:0px 0px 6px 0px"> <!-- BEGIN TEMPLATE: postbit_legacy --> <table id="post8128370" class="tborder" cellpadding="6" cellspacing="1" border="0" width="100%" align="center"> <tr valign="top"> <td class="alt2" width="175" style="border: 1px solid #FFFFFF; border-top: 0px; border-bottom: 0px" > <div id="postmenu_8128370"> <table width=100% cellpadding=0 cellspacing=0 border=0> <tr> <td align=left><a rel="nofollow" name="post8128370" class="bigusername" href="https://forums.pelicanparts.com/members/194350.html">gtgt__bangbang</a></td> <td align=right><!-- BEGIN TEMPLATE: postbit_onlinestatus --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/user_offline.gif" alt="gtgt__bangbang is offline" border="0" /> <!-- END TEMPLATE: postbit_onlinestatus --></td> </tr> </table> </div> <div class="smallfont">Registered User</div> <div class="smallfont">  <br /> <div>Join Date: Jun 2014</div> <div> Posts: 124 </div> <!-- BEGIN TEMPLATE: dto_garage_postbit_userinfo --> <!-- END TEMPLATE: dto_garage_postbit_userinfo --> <div> </div> </div> </td> <td class="alt1" id="td_post_8128370" style="border-right: 1px solid #FFFFFF"> <!-- message --> <div id="post_message_8128370"> dead thread , more posting problems, please reply to OTHER similar thread </div> <!-- / message --> <!-- GUEST --> <br> <!-- Pelican Ad START --> <div class="pelicanadplacement" data-placementid="32"></div> <!-- Pelican Ad END --> </td> </tr> <tr> <td class="alt2" style="font-weight:normal; border: 1px solid #FFFFFF; border-right: 0px"> <!-- status icon and date --> <img class="inlineimg" src="https://forums.pelicanparts.com/images/statusicon/post_old.gif" alt="Old" border="0" /> <font class="smallfont"> 06-21-2014, 06:34 PM </font> <!-- / status icon and date --> </td> <td class="alt1" style="background-color: #E8E8E8"> <table cellspacing=0 cellpadding=0 border=0 width=100%> <tr> <td align=left style="border: 0px solid; border-top: 0px">   </td> <td align=right> <!-- Tech Article Directory Link --> <!-- Old <img border="0" src="https://www.pelicanparts.com/graphics/tech-article-directory-forum.png" width="15" height="15"> --> <!-- Old <a style="color: #000080; font-size: 10pt" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Pelican Parts Technical Article Directory</a>    --> <span style="color: #9C9C9C; font-size: 11px;"><a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/" target="_blank">Pelican Parts Catalog</a> | <a style="color: #45558A; font-size: 11px" href="http://www.pelicanparts.com/support/tech_article_directory.htm" target="_blank">Tech Articles</a> | <a style="color: #45558A; font-size: 11px" href="https://www.pelicanparts.com/promos/" target="_blank">Promos & Specials</a>   </span> <!-- controls --> <a href="https://forums.pelicanparts.com/newreply.php?do=newreply&p=8128370" rel="nofollow"><img src="https://forums.pelicanparts.com/images/buttons/quote.gif" alt="Reply With Quote" border="0" /></a> <!-- / controls --> #<a href="https://forums.pelicanparts.com/8128370-post4.html" target="new" id="postcount8128370" name="4"><strong>4</strong></a> (<b><a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html#post8128370" title="Link to this Post">permalink</a></b>) </td> </tr> </table> </td> </tr> </table> <!-- post 8128370 popup menu --> <!-- / post 8128370 popup menu --> <!-- END TEMPLATE: postbit_legacy --> </div> <!-- BEGIN TEMPLATE: spacer_close --> </div> </div> </div> <!-- / close content container --> <!-- END TEMPLATE: spacer_close --> <!-- / post #8128370 --> <!-- END TEMPLATE: postbit_wrapper --><div id="lastpost"></div></div> <!-- start content table --> <!-- BEGIN TEMPLATE: spacer_open --> <!-- open content container --> <div align="center"> <div class="page" style="width:98%; text-align:left"> <div style="padding:0px 0px 0px 0px" align="left"> <!-- END TEMPLATE: spacer_open --> <!-- / start content table --> <!-- controls below postbits --> <table cellpadding="0" cellspacing="0" border="0" width="100%" style="margin-top:-3px"> <tr valign="top"> <td class="smallfont"><a href="https://forums.pelicanparts.com/newreply.php?do=newreply&noquote=1&p=8128370" rel="nofollow"><img src="https://forums.pelicanparts.com/images/buttons/reply.gif" alt="Reply" border="0" /></a></td> </tr> </table> <!-- / controls below postbits --> <!-- lightbox scripts --> <script type="text/javascript" src="https://forums.pelicanparts.com/clientscript/vbulletin_lightbox.js?v=387"></script> <script type="text/javascript"> <!-- vBulletin.register_control("vB_Lightbox_Container", "posts", 1); //--> </script> <!-- / lightbox scripts --> <!-- next / previous links --> <br /> <div class="smallfont" align="center"> <strong>«</strong> <a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time-prev-thread.html" rel="nofollow">Previous Thread</a> | <a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time-next-thread.html" rel="nofollow">Next Thread</a> <strong>»</strong> </div> <!-- / next / previous links --> <!-- popup menu contents --> <br /> <!-- thread tools menu --> <div class="vbmenu_popup" id="threadtools_menu" style="display:none"> <form action="https://forums.pelicanparts.com/postings.php?t=817304&pollid=" method="post" name="threadadminform"> <table cellpadding="4" cellspacing="1" border="0"> <tr> <td class="thead">Thread Tools<a name="goto_threadtools"></a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://forums.pelicanparts.com/images/buttons/printer.gif" alt="Show Printable Version" /> <a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time-print.html" accesskey="3" rel="nofollow">Show Printable Version</a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://forums.pelicanparts.com/images/buttons/sendtofriend.gif" alt="Email this Page" /> <a href="https://forums.pelicanparts.com/sendmessage.php?do=sendtofriend&t=817304" rel="nofollow">Email this Page</a></td> </tr> </table> </form> </div> <!-- / thread tools menu --> <!-- **************************************************** --> <!-- **************************************************** --> <!-- / popup menu contents --> <!-- forum rules and admin links --> <table cellpadding="0" cellspacing="0" border="0" width="100%" align="center"> <tr valign="middle" align=left> <td class="smallfont" align="right"> <table cellpadding="0" cellspacing="0" border="0"> <tr> <td> </td> </tr> </table> </td> <td width="100%" valign="middle" align=right>   </td> </tr> </table> <!-- <br> --> <!-- BEGIN TEMPLATE: ad_showthread_beforeqr --> <!-- END TEMPLATE: ad_showthread_beforeqr --> <!--Filter for Google ads because the girls pics are too racy. Add other threads below too--> <!-- --> <!-- <!-- <script async src="//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script> --> <!- - Peach Leaderboard - -> <!-- <ins class="adsbygoogle" style="display:inline-block;width:728px;height:90px" data-ad-client="ca-pub-0812980613569064" data-ad-slot="6952955753"></ins> <script> (adsbygoogle = window.adsbygoogle || []).push({}); </script> --> <!-- --> <!-- End ad tag --> <!-- /forum rules and admin links --> <br /> <!-- BEGIN TEMPLATE: footer --> <!-- BEGIN TEMPLATE: ad_footer_start --> <!-- END TEMPLATE: ad_footer_start --> <!--Filter for Google ads because the girls pics are too racy. Add other threads below too--> <center> <!-- begin ad tag (old IB JS ad) --> <!-- <script async src="//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script> --> <!-- Forums Footer --> <!-- <ins class="adsbygoogle" style="display:inline-block;width:728px;height:90px" data-ad-client="ca-pub-0812980613569064" data-ad-slot="0078232551"></ins> <script> (adsbygoogle = window.adsbygoogle || []).push({}); </script> --> <!-- End ad tag --> <!-- Pelican Ad START --> <div class="pelicanadplacement" data-placementid="29"></div> <!-- Pelican Ad END --> <!-- begin ad tag (new IB JS ad) <script type="text/javascript"> if(typeof(cachebuster) == "undefined"){var cachebuster = Math.floor(Math.random()*10000000000)} if(typeof(dcopt) == "undefined"){var dcopt = "dcopt=ist;"} else {var dcopt = ""} if(typeof(tile) == "undefined"){var tile = 1} else {tile++} document.write('<scr'+'ipt src="http://ad.doubleclick.net/N2922/adj/pelicanparts;kw=bottom;' + dcopt + ';tile=' + tile + ';sz=728x90;ord=' + cachebuster + '?"></scr'+'ipt>'); </script> <noscript><a rel="nofollow" href="http://ad.doubleclick.net/N2922/jump/pelicanparts/kw=bottom;sz=728x90;ord=123456789?" target="_blank" ><img src="http://ad.doubleclick.net/N2922/ad/pelicanparts/kw=bottom;sz=728x90;ord=123456789?" border="0" alt="" /></a></noscript> End ad tag --> </center> <br /> <div class="smallfont" align="center">All times are GMT -8. The time now is <span class="time">07:05 AM</span>.</div> <br /> <!-- BEGIN TEMPLATE: spacer_close --> </div> </div> </div> <!-- / close content container --> <!-- END TEMPLATE: spacer_close --> <!-- /content area table --> <form action="https://forums.pelicanparts.com/" method="get" style="clear:left"> <table cellpadding="6" cellspacing="0" border="0" width="98%" class="page" align="center"> <tr> <td class="tfoot"> <select name="styleid" onchange="switch_id(this, 'style')"> <optgroup label="Quick Style Chooser"> <!-- BEGIN TEMPLATE: option --> <option value="3" class="" selected="selected">-- Pelican Parts - vBulletin 2 Style</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="11" class="" >-- Pelican_Mobile</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="16" class="" >-- Mobile_2022</option> <!-- END TEMPLATE: option --><!-- BEGIN TEMPLATE: option --> <option value="17" class="" >-- Pelican Parts - vBulletin 2022 Style</option> <!-- END TEMPLATE: option --> </optgroup> </select> </td> <td class="tfoot" align="right" width="100%"> <div class="smallfont"> <strong> <a href="https://forums.pelicanparts.com/sendmessage.php" rel="nofollow" accesskey="9">Contact Us</a> - <a href="http://forums.pelicanparts.com">Pelican Parts Catalog for Porsche, BMW, Mercedes-Benz, MINI and More</a> - <a href="https://forums.pelicanparts.com/archive/index.php/">Archive</a> - <a href="https://www.pelicanparts.com/support/privacy.htm">Privacy Statement</a> - <a href="https://www.pelicanparts.com/support/privacy.htm">Terms of Service</a> - <a href="https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html#top" onclick="self.scrollTo(0, 0); return false;">Top</a> </strong> </div> </td> </tr> </table> <br /> <table border="0" cellpadding="0" cellspacing="0" style="border-collapse: collapse" bordercolor="#111111" width="100%"> <tr> <td width="88"> </td> <td> <div align="center"> <div class="smallfont" align="center"> <!-- Do not remove this copyright notice --> Powered by vBulletin® Version 3.8.7<br />Copyright ©2000 - 2025, vBulletin Solutions, Inc. <br />Search Engine Optimization by <a rel="nofollow" href="http://www.crawlability.com/vbseo/">vBSEO</a> 3.6.0<!-- Do not remove this copyright notice --> </div> <div class="smallfont" align="center"> <!-- Do not remove <img src="https://forums.pelicanparts.com/cron.php?rand=1766588702" alt="" width="1" height="1" border="0" /> or your scheduled tasks will cease to function --> <img src="https://forums.pelicanparts.com/cron.php?rand=1766588702" alt="" width="1" height="1" border="0" /> <!-- Do not remove <img src="https://forums.pelicanparts.com/cron.php?rand=1766588702" alt="" width="1" height="1" border="0" /> or your scheduled tasks will cease to function --> Copyright 2025 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    <a href="http://www.pelicanparts.com/support/DMCA.htm" target="_blank">DMCA Registered Agent Contact Page</a> </div> </div> </td> <td width="88"> </td> </tr> </table> </form> <!-- BEGIN TEMPLATE: ad_footer_end --> <!-- END TEMPLATE: ad_footer_end --> <script type="text/javascript"> <!-- // Main vBulletin Javascript Initialization vBulletin_init(); //--> </script> <!-- D_T_O 1-1-5 --> <!-- END TEMPLATE: footer --> <!-- temp --> <div style="display:none"> <!-- thread rate --> <!-- / thread rate --> </div> <!-- BEGIN TEMPLATE: vbseo_linkbackmenu --> <div class="vbmenu_popup" id="linkbacktools_menu" style="display:none"> <table cellpadding="4" cellspacing="1" border="0"> <tr> <td class="thead">LinkBack<a name="goto_linkback"></a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://forums.pelicanparts.com/vbseo/resources/images/forum/linkback_url.gif" alt="LinkBack URL" /> <a href="http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html" onclick="prompt('Use the following URL when referencing this thread from another forum or blog.','http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/817304-want-fix-power-steering-return-cooler-line-last-time.html');return false;">LinkBack URL</a></td> </tr> <tr> <td class="vbmenu_option"><img class="inlineimg" src="https://forums.pelicanparts.com/vbseo/resources/images/forum/linkback_about.gif" alt="About LinkBacks" /> <a rel="nofollow" href="https://forums.pelicanparts.com/misc.php?do=linkbacks">About LinkBacks</a></td> </tr> </table> </div> <!-- END TEMPLATE: vbseo_linkbackmenu --><br /><div style="z-index:3" class="smallfont" align="center"><div align="center" class="smallfont">DTO Garage Plus <a rel="nofollow" target="dto" href="http://www.drivethruonline.com">vBulletin Plugins</a> by Drive Thru Online, Inc.</div></div> <script type="text/javascript"> //<![CDATA[ var vbseo_jshtml = new Array(); vbseo_jshtml[0] = "<table class=\"tborder\" cellpadding=\"6\" cellspacing=\"1\" border=\"0\" width=\"100%\" align=\"center\"> <tr> <td class=\"thead\">Notices</td> </tr> <tr> <td class=\"alt1\"> <!-- BEGIN TEMPLATE: navbar_noticebit --><div class=\"navbar_notice\" id=\"navbar_notice_1\"> <!-- guest welcome message --><link href=\"https://fonts.googleapis.com/css2?family=Cabin:wght@400;600;700&family=Cabin+Condensed:wght@400;700&family=Permanent+Marker&family=Poppins:wght@500;700&display=swap\" rel=\"stylesheet\"><style>.register-today { box-shadow:inset 0px 1px 0px 0px #97c4fe; background:linear-gradient(to bottom, #3d94f6 5%, #1e62d0 100%); background-color:#3d94f6; border-radius:5px; border:1px solid #337fed; display:inline-block; cursor:pointer; color:#ffffff !important; font-family:\'Cabin\', sans-serif; font-size:1.3em; padding:10px 24px; text-decoration:none; text-shadow:0px 1px 0px #1570cd;}.register-today:hover { background:linear-gradient(to bottom, #1e62d0 5%, #3d94f6 100%); background-color:#1e62d0;}.register-today:active { position:relative; top:1px;}</style> <table cellpadding=\"15\" cellspacing=\"1\" border=\"0\" width=\"100%\" align=\"center\"> <tr> <td class=\"alt1\" style=\"font-family: \'Cabin\', sans-serif; background-color: #FFFFFF; border: 3px dashed #ff6000; border-radius: 5px; padding-left: 10px; line-height: 1.2em; font-size: 1em;\"> <span style=\"font-family: \'Permanent Marker\', sans-serif; font-size: 2.0em; color: #074fe2;\">Welcome to the Pelican Parts Forum!</span><br /><br />You are currently viewing our as a guest which provides you with limited access. By joining our <strong>free</strong> community you will be able to post topics, communicate privately with other members, upload content and access many other special features. Registration is fast, simple and absolutely free so please, <a href=\"https://forums.pelicanparts.com/register.php\"><strong>join our community today</strong></a>! <br /><br />Looking for information regarding repair or replacement procedures for your European automobile? We have thousands of helpful DIY articles for you <b> <u> <a href=\"https://www.pelicanparts.com/support/tech_article_directory.htm\" target=\"_blank\">right here</a></u></b>!<br> <br> And we\'re not just a forum, we\'re also one of the leading automotive parts retailers for Porsche, BMW, Mercedes-Benz, MINI and many more - please take a moment to browse our <a href=\"https://www.pelicanparts.com\" target=\"_blank\">Parts Catalog</a>, <a href=\"https://www.pelicanparts.com/catalog/accessories.htm\" target=\"_blank\">Accessories</a> or our <a href=\"https://www.pelicanparts.com/promos/\" target=\"_blank\">Current Specials</a>!<br><br><a href=\"http://forums.pelicanparts.com/register.php\" class=\"register-today\">Register Today!</a></td> </tr> </table> <!-- / guest welcome message --></div><!-- END TEMPLATE: navbar_noticebit --> </td> </tr> </table>"; for(var vi=0;vi<vbseo_jshtml.length;vi++) if(fetch_object("vbseo_vhtml_"+vi))fetch_object("vbseo_vhtml_"+vi).innerHTML = vbseo_jshtml[vi]; window.orig_onload = window.onload; window.onload = function() { var cpost=document.location.hash.substring(1);var cpost2='';if(cpost){ var ispost=cpost.substring(0,4)=='post';if(ispost)cpost2='post_'+cpost.substring(4);if((cobj = fetch_object(cpost))||(cobj = fetch_object(cpost2))){cobj.scrollIntoView(true);}else if(ispost){cpostno = cpost.substring(4,cpost.length);if(parseInt(cpostno)>0){location.replace('https://forums.pelicanparts.com/showthread.php?p='+cpostno);};} } if(typeof window.orig_onload == "function") window.orig_onload(); } //]]> </script> </body> </html> <!-- END TEMPLATE: SHOWTHREAD -->
