oil cooler seals
ok, i'm finally doing my oil cooler seal project and since i have that sludge everywhere i was wondering if i could poor gas, mineral spirits or any cleaner down into the oil filler tube so it goes through the system. i need to clean out the oil pan. how should i go about pouring the cleaner into that? also, can i pour cleaner into the dipstick too? it also has sludge.
i'm also a little confused on the whole adjusting part and the washers i need. what is the measurement i have to take and how do i use the alignment tool? |
Use mineral spirits - pour it into the crankcase (dipstick and down the filter housing is fine) and let it sit while you work on the seals - drain and refill with oil/motor flush run engine, drain, refill with oil, repeat after 500 miles.
Will send you a parts diagram when I get home from work tonight. I am somewhat concerned that you have been driving it this way for a few weeks - all that moisture in your crankcase is not good for your bearings. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
ok, so i can pour mineral spirits in just like i do with regular oil then? good..i'll prolly do that tonight and let it sit the night cause it'll need it
ok..how do i get the moisture out then?...also, i have sludge where the upper radiator hose connects to the engine..how do i clean that out too? if i pour mineral spirits into the engine just like i do with regular oil won't the mineral spirits get into the cylinders and stuff? i don't think that's very good for it.
basically anywhere oil and coolant can get i have sludge...where else should i put it that maybe i missed? |
You are going to have to take your hoses off and clean them all out with soap and water - same thing goes with your expansion tank etc. - get a bottle brush and start scrubbing.
Flush out what you can in the oil system with mineral spirits - flush the cooling system with a degreaser. You will probably have to do this more than once - after you have degreased the cooling system, rinse well with water a couple times and then fill with coolant. You will be changing your coolant and oil a couple of times in the next couple of months. Haven't forgotten your diagrams, should have them tonight. AFJuvat
update: oil cooler seals are in and i've been running the car for 2 days with just water in the coolant system..for some reason i'm still getting sludge in the expansion tank. i'm thinkin it's either: the system hasn't fully cleaned itself out yet, the oil cooler seals are in wrong, or it needs a headgasket..i also have been smelling the exhaust and it's not normal. it almost smells like water and oil or somethin' like that. any ideas guys?
