what cars better
is a1983 944 better than 1987
Old 07-10-2014, 06:32 PM
Non Compos Mentis
1983 is a tad lighter.
1987 has better electrical and HVAC systems.
Old 07-10-2014, 06:35 PM
944tothefloor's Avatar
1983 has the manual steering, which is preferred by a lot of "drivers"
Old 07-10-2014, 08:13 PM
plays with toy cars
sausagehacker's Avatar
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/139205-best-944-year.html
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Have 944, will restore
mazdaverx7's Avatar
It really depends on what you consider makes a car better than the other and what options you prefer. Both base cars are built well and perform well and if maintained, can be extremely reliable.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 07-10-2014, 08:41 PM
Back from Beyond
'83.
Manual steering
Forged rods
No ball joint issues
No fuel line routing issues
Lighter
Simpler for the DIY-type owner
Cheaper parts (see above)
Steel control arms easier to work on (and, again, cheap parts)
Not lumbered with systems more at home on a luxury car
Cast header not prone to cracking
Some prefer the manual TB tensioner
The licence plate's in the right place, not hanging off the rear bumper...
Just off the top of my head, of course.
Don't get me wrong, there's a lot to like about Mandy's 87 too, but when I compare build quality side-by-side, the 83's got it. (Her car's gas door is a floppy plastic thing. My 83 and 84 have aluminum ones.) My choice would be an 82 Euro, if I could find one.
But the good thing about these cars is there's one for everybody. If they made an S2 automatic, I'd want one.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-11-2014, 08:01 AM
ABS is great IMO for track days and mountain roads with gravel patches (or ice or cold plus summer tires.) Not having it is no big deal until you flat spot a set of tires or wreck. You need 87+ to get ABS.
If you are more into hard parking the earlier cars can run Fuchs and other "deep lip" wheels you can rest your phone or a dollar bill on.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 07-11-2014, 09:12 AM
Andrew Gawers' Dad
CHICKS's Avatar
No.
Old 07-11-2014, 03:07 PM
alan6272's Avatar
love my 83 would never have a newer people ask to buy mine all the time will never sell
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 07-11-2014, 05:07 PM
Custom User Title
mikepellegrini's Avatar
Driving position on the late cars is a lot better.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 07-11-2014, 10:27 PM
Volhv's Avatar
The late cars have a few advantages:
-Plastic fuel tank, 80 liters! (we've all see the threads about cracked steel ones... and mystery fuel smells)
-Better/lower seats
-Electric speedo, not driven through hole in weakened spindle.
-Proper rear wheel bearings
-Easily replaceable nose panel (How many dented ones have you seen?)
-Does not need spacers on rear wheels for VW suspension to fit 944 body.
-Engines have bigger sumps, and better oil pumps
I find the 86 to be the best of both worlds....
Got the steel front control arms, manual steering, and AC delete on mine, so any advantage an 83 would have had, mine has.
The 86 may be a late car, but it's early offset, so you can run Fuchs, replace your strut inserts, and get cheap VW Fox upper strut mounts. And it's the last year to have an eccentric timing belt tensioner.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-11-2014, 11:29 PM
Arizona_928's Avatar
86 turbo.
early offset. Lots of part interchange...
dolor et pavor
Copyright
Old 07-12-2014, 12:23 AM
Patrick
pfarah's Avatar
I think since I can't afford a 951 or S2 or 968, my 84 NA will do just fine. Besides, I've been going through almost every assembly (inspecting, repairing, and cleaning) so I have a good idea where she stands. She'll be brand new by the time I'm finished... or not...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-12-2014, 10:26 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
The 87 and later 944 model engines have auto timing belt tensioner. Belts last longer, less likely to jump tooth.
Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 07-15-2014, 01:22 AM
ASE Master
alfadoc's Avatar
I think people tend to like what they have, and figure out the appropriate justification for it. Predictably, I'd take my S2 over any other variant.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 07-15-2014, 03:27 PM
Hahah! Interesting point.
Do we love 944s because we own them or do we own 944s because we love them?
I can only speak for myself when i say my 944 isnt awesome because I own it. I own one because theyre awesome.
Old 07-15-2014, 04:17 PM
Later.
You are thinking of the 968. The later 944 cars just have a spring that helps you set the timing belt tension (if you trust it) and then you lock it down just like the early car. You still need to retension.
IMO it's not any better than the early car assuming you have a way to measure the tension. If you are just guessing, it's better.
The 968 has the more modern dampened spring piston that sets and maintains the tension as the belt wears and the temperature changes. Of course the balance shaft belt needs to be checked and re-tensioned so you still have to go back into the 968 for the re-tension, and you still want to check the BS belt regularly, if it breaks it can take out the cam belt and thus the head.
1987 928S4
1992 968 cabrio
Old 07-15-2014, 05:02 PM
