Hatch delamination - fill with silicone?
A small length (about 4 inches) of the upper left hatch seal on my 85.5 is beginning to delaminate. Still watertight, but the noise is driving me crazy!
The actual delamination is, thankfully, happening very slowly - in fact I have not noticed any real increase in this over the past two or so years. Question: as a temporary measure...could I simply fill this gap with some silicone caulking/sealant to quiet things down a bit - and perhaps even slow the delamination process? Has anyone tried this? |
I filled a crack in one of mine with silicone, it stopped water from leaking in and no more wind noise from it. but it's not the prettiest fixes.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
TIG Welder
Use caution!!
I don't have first0hand experience here, so take it with a grain of salt, but from what I've read putting silicon there will make it difficult, if not impossible, to get a good seal when you eventually re-seal the hatch. I'd investigate that carefully and see if there is a better solution. Just my $.02.
'79 SC Targa (SOLD) '85 944 (SOLD) '86 951 (SOLD) '97 Boxster (SOLD) |
No, DO NOT use silicone! While it does seal, it doesn't have strong adhesive properties to stick to the glass & frame. And if you try to re-glue the hatch later, without COMPLETELY removing all of the silcone, you'll have a difficult time with bonding.
If you just want to squirt something in there to fill the gap, use the same type of urethane windshield adhesive that's used to bond glass to metal. Something like this Transtar Autobody - Urethane Windshield Adhesive . Or any of the 3M Windo-Weld type of urethane windshield adhesives will work. No silicone. |
plays with toy cars
I'm guilty of using a silicone based sealant...
I grabbed some at Home Depot that's designed for glass and metal bonding (think: what holds together fish tanks). It should be easily removable with a razor when the time comes to have it professionally redone. I used painter's tape to make sure the sealant was applied directly to the crack. Mostly a cosmetic thing I guess. So far, no more leaks! Before, I could literally see a couple drops every second splash in during a heavy rain. Fixed for $4
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
I had our graphics guy make make us rear strips that wrap around the frame, the hatch that was delaminating, I used a windshield adhesive to bond the glass back to the frame.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Really neat! What a patriotic thing to do to the sunroof!
Thanks, was easier than repainting & fixed a leaky sunroof.
Hatch de-lamination
Is this what yours looked like?
Hatch de-lamination
Years ago I worked on modular window systems for J F Donnelly an assembly like this would be fabricated in a dedicated fixture with the proper primers, adhesive and a complete clamping system (De Staco). I don't believe there is a way to repair this without replicating the suppliers process. It would be helpful to find out who the original supplier of this hatch assembly was.
Have 944, will restore
I will agree that its not the proper method and that the silicone can be tough to scrape off, but it will work in a pinch. My plan is to replace my hatch glass anyways, as the glass is foggy around the defroster lines, so filling the separation with silicone or window weld was an ok option for me. I did it on my 85.2 and have had no leaks since:
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
I have a question. where does the water get in if it delaminates?
1984 944: M456 suspension, KLA strut brace, PowerPROM Race chip, Slotted rotors/performance pads, Only944 short shifter |
