screw identifiers in PET
how are the screw identifications in the PET to be interpreted? for example, here's one that I lost:
Illustration 201-03
part no. N 043 864 1
Screw
BM 3 X 6
what does the "BM" mean? I assume "3 x 6" is millimeters of the head and shaft. I have not found this style of identifier in the usual places (Fastenal, Bolt Depot, etc.), so I am lost when trying to find it in the local hardware fastener drawers.
another screw I have from the same illustration,
N 013 957 5
Tapping screws
B 3,5 X 9,5
this one has a measured thread pitch of 1.25
87 944 NA
Old 08-31-2014, 08:04 AM
968 GUY's Avatar
B is Probably the type of scew, flat or rounded or pan head, but not completely sure.
Pretty sure m means metric. For some reason commas were used instead of periods.
8͵5 is eight and a half.
Had to figure this out also when trying to sort out the random and mostly incorrect screw placement on the dash of the supposed near perfect 6-speed 968 I bought.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 09-01-2014, 06:36 AM
Ornery Bastard
Because they're German. The German convention (and, in fact, the convention in most of continental Europe) is to use commas as separators for decimal numbers. German also uses a period for the thousands separator.
For example, in the US and Great Britain we would render one-thousand point five as "1,000.5" while in German the correct convention is either "1.000,5", or "1 000,5".
Illustration 201-03
Screw
BM 3 X 6
N 013 957 5
Tapping screws
B 3,5 X 9,5
https://en.wikipedia.org/wiki/ISO_metric_screw_thread#Preferred_sizes
Metric screws are given with their nominal diameter first, then length, so, for example, an M6x10 is an M6 screw or bolt that is 10mm long. You may also see something defined as "M6-1.0" which is an M6 screw with a 1.0mm pitch (the standard, "coarse" M6 pitch). Note also that the diameter is the major diameter, which is the diameter at the peaks of the threads.
A standard Metric M3.5 screw should have a pitch of 0.6mm, with a pitch of 0.35mm being the "fine" pitch option.
The "B" is likely a designation for the shape of the head.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 09-01-2014, 12:26 PM
well, it seems I found the screw that is supposed to be "BM" sitting on the car somewhere. If it is correct, it has self-tapping channels in it, and the thread is very fine. Was in a rush so I didn't write anything down.
note to self : buy new screws every time a job is to be done - save yourself massive grief.
87 944 NA
Old 09-01-2014, 02:58 PM
