Ornery Bastard
States do NOT have exclusive control over emissions rules. States are only free to enact regulations that are more stringent than federal rules. Anyone who tells you otherwise is either lying or severely misinformed.
Look, I'm an attorney. Understanding the law is what I do for a living. It is illegal to remove a catalytic converter from a car in every state because it's a federal law. Just because a state stops requiring inspections does NOT mean you're free to remove emissions control devices under federal law. The only time it is legal to remove a catalytic converter is when it has worn out and you are replacing the worn-out unit with a new, EPA-certified, unit. Any state law that says otherwise is invalid because it is in conflict with federal law and federal law controls. All that said, speeding is illegal too. People take risks all the time. If you believe that the risk of getting caught is small enough that you'll accept it in return for not having a catalytic converter, that's your choice. But don't pretend for a moment that removing a catalytic converter is ever legal.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 09-06-2014 at 09:20 PM.. |
Have 944, will restore
That car is so rare and original that I wouldn't modify it one bit. Its absolutely stunning. Why not just enjoy the car the was it came?
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
I hate you a little
John |
Toofah King Bad
No need to remove the cat. . .at this age, depending on mileage, there may be nothing in it.
There are several aftermarket solutions for the 944 (same rear portion of exhaust) that will make the car louder.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
In NY they wont check emissions on anything older than 25 years (all my Porsches and none have been check in NY ever). I am no lawyer but it does appear that the EPA forbids the removal of a cat and considers it "Tampering" however the reality of the mater is that unless you have an EPA agent (if those exist) living next to you there really is no way for them to realistically find out. They are not going to start looking under every loud car out there to see if the cat has been removed... ...are they?
What you need to make sure you do is keep the noise level in spec. I think its 108 DB, this is something that cops will give you a hard time about and the issue is that its somewhat subjective (and I have had this issue back when I raced formula cars that were checked for noise levels). The placement of the DB meter will drastically change the reading, most people will try and get it as close to the tailpipe as possible but heat can be an issue in this. Even the angle of the meter to the tailpipe will matter, further more a slow to respond meter may give you a different peak reading than a fast meter (due to the harmonic nature of an engine running).
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Ornery Bastard
Whether any classic mechanic is likely to actually do that is another story. I'm not against removing the cat on an old car. I've heard stories, of people removing the catalytic converters from 944 Turbos and still passing tailpipe emissions tests. But I'm not a fan of people making choices based on bad information. Everyone breaks the law at some point. I speed. A lot. I accept the risk of a ticket. The fine for removing a catalytic converter is $2,500, which is a relatively small amount, as federal fines go, and the chance of discovery is low for most owners. So I can see how some would decide that the risk is acceptable. That's fine. Just go in knowing that you're making that choice.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Regards Dave
i didn't realize this was going to turn into an in depth discussion of catalytic converters!..
leaving aside that controversial topic for a second, can anyone recommend a good exhaust solution-i'm not looking for it to sound like a formula one car, but at the moment, it sounds as though i'm driving a dyson vacuum cleaner (but slightly more exciting..) ![]() |
No personal experience but as Rasta said there are many 944 options and the turbo "cat back" should be a direct bolt on as it has a 4 bolt flange like our cars. The 944 NA has a 3 bolt flange.
See here for a 931/944T exhaust comparison. 924Board.org :: View topic - 951 cat back on a 931 Exhaust examples. EXHAUST / RELATED at LINDSEY RACING - Your Porsche Performance Parts Center
1982 931 |
I once had the catalyst break free and it was obstructing the exhaust and it ran very badly. I dropped the rear pipe and removed the obstructing catalyst biscuit. The car continued to pass emissions and run fine after that. I have no idea if the hollowed out converter performed (HP wise) any different than a straight pipe. But certainly nobody could tell the catalyst was completely inoperative.
The PO of my 944 replaced the end piece and muffler, not sure who makes it but ill check when Im near the car again. Its a tasteful mod nothing to nuts. It adds some nice low end to the car. The one thing to watch our for is that high pitch honda civic rasp. I have seen a few 944's in passing that had the better part of a soda can welded to the end of a terrible muffler. The sound is reminiscent of putting a baseball card in your bike spokes. If you can try and get near some local 944's and hear them. Where about in NY are you, I keep my 944 in Westchester and you are welcome to come by hear it next time Im up there.
Regards Dave
Carrea gt nice car
Cat gone
The newest of the noobs!
If your car was intended for the European market, there should be no cat. I have a cat delete Euro exhaust in my garage with nothing to do. It's a bit beat up, but I'll check it out.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
Andrew Gawers' Dad
BTW, this is for a 924 Turbo.
They are Parting out 924 turbo in miami
I have a billy boat stainless cat-back on my turbo. Maint free. Reasonably quiet until you get on cam then it opens up nicely. Not sure if you can find them though and spensive if you do. Might be hen's teeth.
Will work with or without a cat, har. |
Porsche 944S Club Sport
Big congrats.
Will you bring it out to the PCA NY Metro grand concourse show in West bury, NY? We need more pics please. I would love to see it and meet you there...Pm me when you get a chance... Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
The garage in this video looks quite familiar...
https://www.youtube.com/watch?v=cwwHULWCmkI&feature=youtu.be Is that you? If so I hope you come out to the thanksgiving gathering this year I would love to meet you. Regards Dave
