2 questions
1st, I replaced my oil pressure sending unit, and now it leaks. Is there a better way to tighten it than to undo the power steering?
2nd, what is the preferred method of running a wire through the fire wall, do I need to drill a hole, or is there one already there that can be used?
Old 10-14-2002, 06:08 AM
AFJuvat's Avatar
You can tighten it down with a 24mm crowsfoot wrench and a 10" extension without removing anything.
There should be an access through the firewall near the fusebox.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-14-2002, 07:03 AM
Thanks AF, your response time is incredible.
Old 10-14-2002, 09:11 AM
