Broke nipple off brake fluid reservoir, any way to avoid buying another?
Sent from my SPH-L720 using Tapatalk |
I have broken no less than 2 of them my self. The PO of my 944 was able to use epoxy to hold it on and its held up for the past 3 years no issues. Just use lots of epoxy. You could try to use some thin metal pipe in the nipple and then have it run into the reservoir to ensure a nice joint, then lots of epoxy around that. Think male-male connector.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Andrew Gawers' Dad
Nope, buy another one. Tons of used ones out there.
Andrew Gawers' Dad
The last fluid you want to lose is brake fluid, why the fuch would you use epoxy to fix something so important?
1986 Porsche 944 Base Coupe - Brake Hydraulics - Page 2 |
Andrew Gawers' Dad
Or, I bet if you searched for 2 minutes you would find a dozen used ones here: Porsche 924/944/968 Used Parts For Sale & Wanted - Pelican Parts Technical BBS
For something that important I would source out a good used unit first and repair it as a very last resort.
I'd be inclined to ask on the used board as has been suggested. eBay results are not very informative on this matter, are they? Informative, yes, but of what? And how good?
Or ... nice brand-new reservoir, gotta like that! And keep our host up! |
Custom User Title
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Reservoir
Have this one FS. The float SW is missing a contact so just use your cap or parts from it.
![]() ![]() crossrocker; Sent you a PM . K Have a ton of parts in two photo bucket accounts: Numbered Listings 944 924 Photos by kwandrey | Photobucket 924-944 Parts Photos by Kens_74_911s | Photobucket
Ken - ebay: wandrey1 , *0 , *00 , *01 74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3 81 VW Caddy Pickup X2 now... 84,85x2 .86,87,944. 82-924,88-924s parted with inventory! 68, 70, 72, 73, 911~ 70,73 914 past P/cars |
less I know,more I learn
I also have a spare reservoir. There should be one around where your located. Don't use epoxy on a master cylinder. The hydraulic brake fluid is so corrosive. Never ever use any kind of epoxy no matter how good it is on a hydraulic system. All you need is a reservoir. Replace it. Don't try to fix it. Throw the broken reservoir out.
Raymond |
Just to share a funny story on this. I once met up with a guy who was parting out a 944 to buy some odds and ends for mine. I knew there was epoxy on my break tank and it had always been like that (i assume from a similar situation) anyway the parts car had a good tank so we were pulling it out and while trying to remove the clip we broke the nipple off. We both started laughing and came to terms with the fact that at some point every 944 owner has done this.
Maybe ill spend some time trying to design a better aftermarket tank... Regards Dave
Anytime I run into stuck hoses on a plastic fitting I remove the clamp and slice the hose with a razor and very carefully remove it. Just had a look on eBay and there's lots. Early and late,reservoir with master,without master. Averaging from $20-60.
Raymond Last edited by Backyardbodyman; 12-10-2014 at 07:19 AM.. |
Cut the hose on these wimpy nipples
+1 on carefully cutting the hose off with a razor; these nipples are way too easy to break. I assume this is the nipple that feeds the clutch, can you clean up the hole and screw in a metal fitting or screw in a hollow metal rod?
![]() Probably best to buy a new or used reservoir though I do not see one on Pelican's site for my 1988. I tore the nipple on the clutch master cylinder, it is also weak plastic. From now on I'll use a scalpel and surgically remove the hose. Plastics can be welded (Harbor Freight has several plastic welders) but I have not done it so I don't know how strong the repair is. See a guy weld a tank: https://www.youtube.com/watch?v=k_Fkhz2G9Is Also interesting: https://www.youtube.com/watch?v=cAjTsIkTq0M
1988 Silver 924-S Original owner Porsche 924S: The 944's cheaper, faster little sister.
I purchased a used reservoir and it's on the way. As far as the metal nipple goes, a friend of mine suggested it but there's no visible way to get onto that side of the wall. Or else this would been a great permanent solution. Sent from my SPH-L720 using Tapatalk |
Better late than never : I can vouch for kens_74_911s - thanks again for the great service and accurate description of the NLA used fuel/brake line clips/nuts/rubber mounts! They work perfectly!
![]() Sent from my SPH-L720 using Tapatalk |
