Oil leak project
Next 968 project is to tear down engine lower to:
1. Replace balance shaft o-ring 2. Reseal lower balance shaft cover 3. Change oil pan gasket 4. Clean pickup screen 5. Replace rod bearings & nuts 6. Reseal exhaust & replace hardware 7. Reset heat shields 8. Retension timing belt (check) and balance belt 9. Replace oil pressure sender 10. Change oil Any thoughts on what else to do? Belts etc. were done recently.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Kessel run in 12 parsecs!
I have a oil leak on the back of my camshaft box, I dont have time to pull the engine or remove anything to fix it. But its a leaker! lol. Yeup the oil pan leaks on these cars. I have the turbo, so its a night mare. I know Ed China and Anthony from wheeler dealers could pull this motor. but I just let it drip into a pizza box with cat litter soaking up the oil. Point of my response is, check your back of your cam box for leaks also.....
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
Engine mounts, if there is any doubt. Maybe just replace the right. if they are old but OK. I'm still happy with the Meyle mounts in my 968.
Small power steering hoses can be easily replaced. Crumbling hall effect sensor connector can be replaced. Or wrapped in that clay putty glue stuff. Any sway bar bushings, A arm bushings, as that's all coming off and the car will need to be aligned. As such brake discs, pads will also be handy Heater valve, if it's the OEM style that cracks in half, could be swapped for a metal version. Lots of good degreaser and plastic putty knives help with this job. The gel degreaser is good, the walmart stuff is cheap. I am not sure which is better value. If there is a place to run a steam cleaner or dry ice blaster on it that's not too expensive that might be worth it.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS Last edited by Jfrahm; 11-22-2020 at 06:54 PM.. |
Just did most of this recently. All my oil leaks were fixed for almost three months. Now I noticed a drop of oil coming down from the turbo.
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
944 addict
Like harley's, if it ain't leaking then you're out of oil.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
LOL, Euro cars dont leak, they just mark their territory. I saw a how to in an early easy rider to stop the leaks. The tore it all down to the crank case halfs, and the epoxied or some kind of sealant spread on both half crank case, it was red in color. they let it dry , re assembled it, and presto, a leak proof harley..
944 addict
Supposedly this turbo was replaced by the PO. It looked good... When the time comes I may consider a 26/8 or the Vitesse Stealth turbo. I must decide if I want to go down that rabbit hole.
