1986 944 Base - Anyone have issues with the clutch pedal sticking to the floor and after replacing the return spring it solved the problem? or is this the beginning of a larger problem?
- Phil Long 1986 944 Base - Daily Driver |
Something is wrong with your hydraulic system.
Look for a puddle of brake fluid under your bell housing. Look for a "mysterious" disappearance of brake fluid from your reservoir. Replace both slave and master cylinders at the same time. Google "944 clutch slave cylinder bleeding", it can be a real pain to get all of the air out of the system.
Good luck, George Beuselinck |
Thanks.
I replaced the slave cylinder 4 years ago. Should I try replacing the master cylinder first or replace both like recommended?
The answer to your question is hidden in the answers to my questions.
Looks like I'll do both. Appreciate the input.
Correct, do both while you are at it.
'87 944 Turbo |
Air in the system.
Vacuum bleed, or power bleed. If it leaks replace both at the same time. 4/5 years is all I would get out of a Clutch master/slave when DD my old N/A
dolor et pavor Copyright |
Thanks guys. What's the best way to bleed the system to see if there's any leaks?
Motiv Power Bleeder is the best.
I created my own using a pesticide sprayer. One of those air pump ones...
'87 944 Turbo |
Non Compos Mentis
+1.
Power bleeder makes it a very simple one-man job. |
