Plug for brake lines
Does anyone know what size or if there is a steel threaded plug that will fit into the brake lines to keep brake fluid from leaking out while the calipers are off of the car? Thanks, Joel
Old 10-07-2015, 10:11 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You should be able to just clamp the hose vs plugging the line. There's some cheap rubber faced clamps at home depot or harbor freight. I have one clamped to my fuel tank line right now and no leaks. Threading something into those lines can cause leaks from internal cutting of the rubber.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-07-2015, 10:33 PM
Arizona_928's Avatar
I have used a piece of rubber hose and a bolt. hose clamp if it doesn't seal as is. cheap, dirty, but effective.
dolor et pavor
Copyright
Old 10-07-2015, 10:58 PM
I use the rubber test caps from the mityvac kit without spilling much.
Old 10-08-2015, 07:53 AM
911tracker85's Avatar
to tie off brake lines for some work, such as replacing old rubber lines with new braided lines, I found a metric 'set screw' that would screw into the female fitting on the hard line where the end rubber line to the caliper disconnects. don't recall the mm /pitch now, but it is common.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 10-08-2015, 01:07 PM
if your car still has the rubber cap over the end of the bleeder valve, those fit the end of the steel line perfectly.
Old 10-08-2015, 01:56 PM
That Guy
Techno Duck's Avatar
I have used a female 10x1.25 concave seat to a -3AN fitting. Then just get a -3AN cap. Worked great for me when i had my car disassembled for an engine swap.
https://www.pegasusautoracing.com/productdetails.asp?RecID=4203
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-08-2015, 03:15 PM
Thanks, Techno Duck. Joel
Old 10-08-2015, 10:27 PM
For standard rubber hose lines (not stainless braided teflon?) I've used needle nose vise-grips with pieces of rubber hose slipped over the jaws so as not to damage the brake hose.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 10-09-2015, 11:15 AM
