darnellsgarage
A/c will not engage
Was working fine. Stopped working. If I push a/c button it won't stay on. Swapped out relay, checked fuses. Where to look next?
don
Old 10-05-2015, 08:32 PM
Proprietoristicly Refined
John_AZ's Avatar
If low on Freon the "low pressure switch" near the receiver dryer will not let the compressor engage,
You can jump the low pressure switch with a paper clip and if the compressor engages you found the problem.
Maybe??
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-05-2015, 09:20 PM
Arizona_928's Avatar
Radiator fans function?
dolor et pavor
Copyright
Old 10-06-2015, 12:42 AM
