-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   engine sensors? (http://forums.pelicanparts.com/showthread.php?t=89219)
JH924S 11-30-2002 10:15 AM
engine sensors?
how do these actually come out. i have taken every bolt off and the bellhousing still wont come off and i have not removed the sensors as i cant see how they do . todwic i think u figured this out the hard way right? do they pull straight out? TIA
Scott R 11-30-2002 10:50 AM
They get stuck over time. Be carefull but try twisting them a bit to loosen them up.
Once both of the bolts are removed that just slide straight up. But the last two times I have done one they were a bit frozen.
JH924S 11-30-2002 11:19 AM
thanks a lot, man are they a pain to come out in this cold weather and no room to work with
todwic 11-30-2002 04:13 PM
Hell, just take the bell housing off, and the important half comes with em!<p>
TDC and RPM sensors from a Junkyard: $60<br>The bracket to hold them: $5 xtra<br>Knowing to pull the sobs before you yank off the bell housing: Priceless<p>They fit in real tight, try some WD-40 and let it soak for about 20min. Soak em real good.
