daveimme's Avatar
Send a message via Yahoo to daveimme
Basic questions here
I'd like to know what the oil pressure should be when the car has warmed up and at idle......for a while the oil pressure was always pegged whenever I cranked it up....lately it is pegged only under acceleration or above 1500 rpm......at idle (900-1k rpm) it will sometimes be 3 (3 bar?). I'm using castrol syntec blend 10w 40, if that matters.
Also, has anyone put on a gauge for the alternator on their car? If so, where did you place and what model gauge used? VDO? I would like to mount one, but I can't figure out where to put it.
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 12-19-2002, 07:31 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
Porsche Crest
Sounds normal to me.
Old 12-19-2002, 07:56 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
My oil pressure does the exact same thing. From what I know your fine untill it reads 0, then you have problems. As far as the alternator goes, I haven't had any problems with mine yet (I'm knocking on wood, A LOT) so I'm of no help there.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 12-19-2002, 07:58 PM
AFJuvat's Avatar
Dave - you sound about right with the oil pressure - on a hot day here it can drop to 1.5 bar.
never played with adding an alternator gauge - the one in the car is acoutally pretty accurate - it yours is acting flaky remove the cluster and clean the grounds - should snap right back
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-20-2002, 03:08 AM
When the engine is hot, I've noticed my pressure drops to a little above 1 1/2 bar. Normally it's 2-3. If your pressure goes below 1 bar then the oil pressure low light comes on.
-Dave-
1969 911/3.0l SC
Old 12-20-2002, 04:33 PM
fletch944t's Avatar
Send a message via AIM to fletch944t
Oil Pressure
When you first turn the ignition switch to the "ON" position (where all the accessories and lights come on), the oil pressure should peg high.
Then when you start the engine the oil pressure should come down to about 4-4.5 bar at idle.
As the engine oil warms up and the oil thins out the pressure will steadily drop until it get to about 2-3 bar at idle (normal operating temperature).
If it is consistently running high, expecially after the engine is completely warmed up, there may be a problem with the oil pressure sending unit. However, it could be a loose or corroded connection at the sensor. Try cleaning the connections first and see if that helps.
If the oil pressure runs well below two bar at normal operating temperature, it may be indicative of worn bearings, a problem with the oil pressure relief valve, or a problem with the oil pump. If pressure falls below 1 bar, you shouldn't run the engine until you determine the cause of the low oil pressure.
Sorry about the length of the post.
Regards,
Clark
Clark Fletcher
1986 2.8L 951
Clark's Garage
http://www.clarks-garage.com
Old 12-21-2002, 06:29 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
perfectly normal. Mine never drops below three, but it takes a good 10 mins to get there from 5. Only worry if it drops below 1 or so.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 12-21-2002, 08:00 AM
I ran Mobil 1 20W50 (advised by a mechanic) and my oil pressure was 3.5 - 4.0 bar at idle and pegged while driving. I was getting some leakage at the valve cover and the oil would drip on my exhaust manifold. Talk about embarassing. I switched to 10W40 Mobil 1 and now my pressure is 2.0 at idle and 4.5 while driving and the leak stopped.
Old 12-21-2002, 08:28 AM
daveimme's Avatar
Thanks guys....I feel better now. It appears to be working just fine....unit may have been sticking or something from sitting up for some time and finally came around. When first started...pegged, warmed up and then at idle is about 2-3...on the gas over 1500 rpm 4.5-5.....so, I'm content with this now.
The alternator......I don't have a problem with mine, but it is an idiot light....I want one that has a gauge so I can see if and when it is failing... I feel much better when I can read how much voltage it is putting out. That's why I was thinking of putting one in and wonder if anyone has and if so, where is placement...
Old 12-21-2002, 02:22 PM
carolinus's Avatar
Placement.
I believe VDO makes a voltage gauge. I would put it in the hole for the habitually broken VDO clock.
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 12-21-2002, 03:24 PM
daveimme's Avatar
Re: Placement.
Not a bad idea...but mine works
When I first got the car about 3-4 months ago, my little kids were wondering what that 'gauge' was They figured it out, but they had never seen an analog clock in a car before, and having one that works is cool.......But, if it were broken, that would be the perfect spot for it....
Old 12-22-2002, 06:16 AM
