cooling fans running
My cooling fans have turning on in the garage in the middle of the night. Please let me know any tests for the sensors and relay.
Thanks,
Old 07-19-2016, 12:37 PM
Certified Porsche addict
The Glademister's Avatar
Cooling Fan Operation and Troubleshooting
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 07-19-2016, 01:13 PM
sjv sjv is offline
fans
I to had that problem I removed the fan relay removed the cover and found the relay points making contact needle nosed them apart never a problem sense .Pulling that relay to keep my battery from dying lead me there / did buy a used relay new costs are very high good luck
Old 07-19-2016, 03:25 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
The most common source of this problem is the radiator temp switch. It bit me at Disneyworld when the battery went dead middle of the night. As soon as the aide jumped me, the fan came on. That's only supposed to happen as a backup for higher than normal coolant temps.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-19-2016, 04:51 PM
ernie9944's Avatar
Been there with my 968 ....cooling fan relay was the problem.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 07-19-2016, 06:21 PM
Thanks to all. I wouldn't be able to keep the 944 without all the help I receive from you guys.
Kudos
Old 07-20-2016, 07:37 AM
Before messing with the relay, check the temp sensor in the radiator just below the hose on the right side. That is the first thing on the trouble shooting list to check. Disconnect it and if the fans stop running, you've found the issue. They are about $30 and about an hour of work to change out. You have to drain the coolant. Also use a socket to remove the sensor. When installing the new one, be SURE to start it in by hand to make sure it's not cross threaded when you start to tighten it with the socket. Much cussing, wailing, and gnashing of teeth will ensue if you screw up the threads in the radiator reservoir.
Dropping the fans, removing the upper radiator hose, and removing the air box gives MUCH better access to allow you really SEE what you're doing.
Old 07-20-2016, 07:51 AM
Toofah King Bad
Rasta Monsta's Avatar
When my car did this it was the AC relay.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-20-2016, 08:37 AM
