ImClueless's Avatar
Question rebuild question ?
I am going to rebuild my 944 turbo motor in a couple weeks. I need to know what to buy or what should be done in a rebuild. So far i have the
1. rings
2. rod bearings
3. main bearings
what else am i missing here guys..
Lon, Im Clueless, Elliott
1987 944 turbo Guards Red
http://committed.to/speed
the home page is a work in progress
Old 01-01-2003, 02:09 PM
Hate to tell you but you're shy a few items.
balance shaft bearings
balance shaft cover rear o-rings
oil pickup 0-ring
Front seal and race kit
oil pump drive sleeve
Headgasket set
rod nuts
rear main seal
oil pan gasket
camshaft bolt
rebuilt waterpump, thermostat, shim
belt and roller kit
loctite 574 case sealer
hylomar sealant
o-rings for oil/air separator(oil filler)
Old 01-01-2003, 04:22 PM
add to that the oil cooler seals, oil filter, umm I'm sure I'm forgetting some stuff
Old 01-01-2003, 04:25 PM
Scott R's Avatar
Get a kit. Since I don't see one listed on Pelican, Zimm's sells one for a complete rebuild. Although I am willing to bet that Pelican can get you a kit put together. But like Highboost stated, you will need a ton of little seals and such.
Lets not forget that since we have the engine out, we should reseal those pesky turbocharger O-rings.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-01-2003, 04:48 PM
Yep, and while the motor's out put in some new motor mounts. Sorry but it's the "and then" and "while you're there" principles.
Old 01-01-2003, 06:17 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
When in doubt replace, better to do it right the first time then to have to do it all over again.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 01-01-2003, 07:39 PM
ImClueless's Avatar
yeah thats what i heard, "while your in there"... I have about 2 grand to buy the parts and me and a couple buddies are doing the work ourselves. We have a 2 and 1/2 week window. If i have the parts on hand. Do you think it can be done... thanks high boost for the list, as my name indicates, im clueless. This will be my first engine rebuild of any kind. Im not an idiot, just not sure what i will need...
Old 01-01-2003, 08:13 PM
ImClueless's Avatar
i tried searching for Zimms but i couldnt find anything, you wouldnt know the web address would you?
Old 01-01-2003, 08:24 PM
ImClueless's Avatar
i guess what i really need is a list of what is done on a rebuild. Then i can buy the parts. You know what i mean. Like
1. rings
2. main bearings.
LOL it would help greatly..
Old 01-01-2003, 08:26 PM
ImClueless's Avatar
i found zim's and they have a hell of a deal on a rebuild kit, all the seals and gaskets, main and rod bearings, nuts, and rings for like 550.00, i think thats how im gonna do it... probably buy 2 new motor mounts while im at it...
Old 01-01-2003, 08:35 PM
ImClueless's Avatar
hey another stupid question here. Anyone know of a rebuild procedure for dummies, i have the haynes but its not really clear on the procedure, it jumps around alot. My buddy has the shop service manuals but i havent looked at them yet..
Old 01-01-2003, 08:41 PM
AFJuvat's Avatar
Private Message me....
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-02-2003, 03:30 AM
overkill's Avatar
Send a message via AIM to overkill
Re: rebuild question ?
1. rings
2. rod bearings
3. main bearings
oil pickup 0-ring
Headgasket set
rod nuts
rear main seal
oil pan gasket
camshaft bolt
belt and roller kit
hylomar sealant
HA HA HA!!! That was funny. ImClueless,... please be carefull and take lots of pictures and notes. Thats all I have to say.
{1987}944S - (SOLD).
Old 01-02-2003, 05:58 AM
AFJuvat's Avatar
heheheh actually, that list is shy as well...
AFJuvat
Old 01-02-2003, 06:41 AM
Ummm, what am I forgetting? A mechanic to put it together? JK!!! Seriously though, what else other than the basics such as oil, antifreeze, and atf for the pwr steering, I can't think right now. Oh BTW, use reg. dino oil, not synthetic, just to let the rings seat.
Old 01-02-2003, 08:18 AM
Was it the headgasket the reason why you were rebuilding the motor or the t-belt broke? Either case you're going to need at least the exhaust guides, and all the seals replaced(comes in the headgasket set, guides don't). The deck will will need to be resurfaced too. If you need the head work done, let me know.
Old 01-02-2003, 08:25 AM
AFJuvat's Avatar
I was going along the lines of:
journals checked for out of round or taper
cylinder bores checked for spec. Rebore and alumasil as necessary.
Lifters checked for cracks or wear
blah blah blah
AFJuvat
Old 01-02-2003, 09:08 AM
Ah, I see, as far as parts go then he should be covered. Machine shop services are a whole different ball game. It wouldn't hurt to have a shop(if they're in good shape), polish the journals, clean the crank and oil passages and allen plug it. If there is debris inside of the crank, it will be distributed throughout the new engine. Same for the block, the oil passages need to be really clean.
Old 01-02-2003, 09:22 AM
ImClueless's Avatar
the head blew on it and i figured, since it has 160,000 miles anyway, a rebuild cant hurt...thanks for all the info guys. I think the zim's kit is the way to go.
Old 01-02-2003, 11:09 AM
Clueless,
is this a daily driver? The aloted time you indicated suggests the 951 might be your reliable transportation? AFJuvat makes a worthy point. If machine work is needed on the motor this will put a serious extension on your rebuild. Maybe just pull the head first to inspect your cylinders and pistons for signs of premature wear. As for your parts list, the rebuild kits are the way to go for sure, but seals and o-rings are only half the battle. Highboost brought up the dreaded "while your in there factor" this is a lot of stuff! Let me add to the list of to do's as well,
clutch, pressure plate, and machine flywheel, throw out bearing
H2O hoses
vaccum lines
intercooler/ radiator flush
tools
beer
any performance mods?
valve guides/seals/springs if needed
Where are you at in VA?
Old 01-02-2003, 02:28 PM
