-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Air Flow Sensor (http://forums.pelicanparts.com/showthread.php?t=92813)
Louie1411 01-02-2003 05:03 PM
Air Flow Sensor
I am about to install a new AFM and Throttle Position Switch. I have no shop manuals but it appears to be a basic "remove and replace" operation. Are there any hidden pitfalls that I need to be on the lookout for? Or any tips for that matter?
Scott R 01-02-2003 05:40 PM
No it's easy. When you install the TPS it needs to be adjusted so that when the throttle plate is closed you hear a "click" as the switch is depressed.
Scott R 01-02-2003 06:34 PM
What's wrong with the factory preset? If the original plug has not been drilled and the cover is intact, then why monkey with it?
Louie1411 01-03-2003 04:31 PM
CO Level or factory preset
IS the factory preset on the AFM OK to go with or if not..How the hell do I set the CO level?
Scott R 01-05-2003 09:03 AM
I have just dropped one in and had it work fine, even passed emissions with flying colors.
I specifically looked for one that had not been adjusted before. Meaning that the adjustment screw cover was in place, and that the top still looked sealed.
