Belt whine fix
Just something worth mentioning. I've had pretty loud belt whine since I changed my belts and I just recently replaced them again. It sounded just as loud as before so I really loosened the balance belt... Didn't make any difference. What it ended up being is I had to adjust the balance belt idler up so there was a 2-3 mm gap at the bottom. That got rid of it. Now there is almost no whine while cold. Something worth trying if you are sick of waiting for the engine to warm up.
-1986 944 NA
Old 02-10-2017, 07:50 PM
Hi Stephen, Were you using Gates Belts? Remember to readjust the tension on the Balance Shaft Belt at or before 1,500 miles.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-10-2017, 09:34 PM
From the sound of it your idler was too close to the lower balance belt gear.
There should be tons of clearance and the idler should be almost touching the long span of belt from tensioner to upper B-shaft.
Old 02-11-2017, 06:52 AM
Can you give me more info on this. My 968 had all new belts and rollers recently and the belt whine is crazy loud. My car sounds like I'm driving an electric motor. Below 2800 rpm I can't even hear the engine only belt whine.
2011 Cayenne
2007 997 Turbo
1991 964 Turbo
2005 955 Cayenne
Old 02-12-2017, 08:11 PM
The timing belt on the 968 is not adjustable for tension - there is an automatic hydraulic tensioner for that.
The balance belt is still 'manual' like the 944 and most people set (incorrectly) them about as tight as the timing belt when it should be much looser. The balance shaft belt runs very loose actually...too tight and it whines like crazy. You should be able to grab the long span of the belt between the upper balance shaft gear and the lower tensioner and twist it between your thumb and finger 180 degrees on itself and no more.
Old 02-12-2017, 08:24 PM
Yeah, the first time I ever did the belts on mine, I got the balance shaft belt too tight. Whined pretty loudly.. Loosen it up to where you can twist it about 100-120 degrees by hand.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 02-13-2017, 08:11 AM
Is it a big job to get that cover off for adjustment?
2011 Cayenne
2007 997 Turbo
1991 964 Turbo
2005 955 Cayenne
Old 02-13-2017, 08:51 AM
I use a stethoscope to listen to the rollers for Telltale whine which means something's to tight water pump roller and your two tension rollers on both belts
Old 02-13-2017, 09:30 AM
You also want to be tensioning the balance shaft belt tensioner in the clockwise Direction and not counterclockwise
Old 02-13-2017, 09:35 AM
Boeing - no, there are 10 or 11 10mm head bolts (11 bolts for a 944 but I think the 968 cover was revised a little) that are pretty easily accessible but you'll need to jack the car to get to the bottom ones.
Old 02-13-2017, 09:43 AM
Ok thanks I'll get to it one of these days.
2011 Cayenne
2007 997 Turbo
1991 964 Turbo
2005 955 Cayenne
Old 02-13-2017, 11:00 AM
