SoCal Driver's Avatar
Todwic, since you have just "handled your crank" you will remember how blunt it is.
The counter weights that is.
Now think about those blunt edges swinging around at 6,000 RPM and all the air it has to push aside. Make them sharp and though they have to push aside the air it's far less of a drag. The following or trailing edge is sharpened too.
Since you have removed a considerable amount of weight off of the crank you can remove the counter balance shafts and recover the bit of horse power it takes to spin them besides take them along for the ride.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-24-2003, 11:44 AM
