930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
83 has heat on all the time
cool car but its miserable to drive with heat on all the time. installed new coolant valve and its adjusted properly. any other common issues I can check?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-08-2017, 11:03 AM
If you pull the face off where the slide arms are located, there are three cables back there and the metal retaining clips can fall off or brake, which will cause the flapper door for the heat to stay open. My 82 924 had the same problem. but that cleared it up.
First pull the radio out, then use a offset Phillips head or a stubby to remove the 2 screws on the bottom of the face plate. place all the levers at their cold points, and you can pull them out by hand.
Remove the face plate and you should see the cables in there and the 3 metal clips.
If there are all present and holding the cables you will need to check the cable next to the heater box under the dash.
This cable in on the drivers side about halfway up. the best was to get under there is slide the seat all the way back and lay on it, its a little uncomfortable at first, then your legs fall asleep and its great after that! Some of the cars have a plate blank off on the side of the heater box where the cable is at, but most do not, you should be able to see the cable, follow the cable to the push point and see if the metal clip is still there, if not, use a heavy zip tie to hold it in place.
I hope this helps you out.
Old 02-08-2017, 11:25 AM
mhariush's Avatar
944 HVAC Operation and Malfunctions
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 02-08-2017, 11:46 AM
h20cooled7's Avatar
cool ill check it all out, are the 924 manuals for hvac the same for early 944s?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-08-2017, 05:56 PM
You are welcome . 80 and on 924's are the same as early 944s.
Old 02-08-2017, 06:20 PM
h20cooled7's Avatar
nailed it. 3 cable hold downs snapped. wasnt gonna rip dash out and replace hvac box. did some . chimpravising and made hold downs. lubing mechanism helped out a lot also. about 2 hours ripping radio and center console is all it took . thanks for feedback, works nice now .
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-12-2017, 03:46 PM
Awesome!! I'm very glad you could get it fixed! Enjoy your 944 to the fullest now :-)
Old 02-24-2017, 12:46 AM
Patrick
pfarah's Avatar
Congrats on getting that fixed. Since those plastic tabs are fairly brittle, I recommend locating a spare just in case. Porsche stopped carrying the control switch a few years ago.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 02-24-2017, 05:40 PM
