carolinus's Avatar
Time to fix it - what do I need?
Hokay...My 944 just took out the head gasket. Coolant in the oil, strange idle I can't seem to get to go away, and oil leaking out from under the head.... Also, a general lack of power.
My plan: Put in a new head gasket, new timing belt, new balance belt, new water pump, oil exchanger seals, cam housing gasket, new belt tensioners, the works. What do you guys recommend as a good basic parts list for this job?
Right now I have:
Head gasket kit.
Cam housing gasket.
timing belt.
Balance belt.
Pelican's front end reseal kit.
Oil cooler seals.
Water pump.
Also, do I need new head studs, or nuts and washers or both?
Also, is there anything that you think I should do to the head while I have it out?
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 01-23-2003, 12:51 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I'd get new washers, tho the manual sez you can reuse em if you sandpaper scuff em up. You know....while you're in that area....belts a-flyin...might as well....RESEAL YOUR BALANCE SHAFTS! For which you'll need two seals, poly rings, rear O-rings and some Loc-Tite 574.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-23-2003, 01:04 PM
carolinus's Avatar
Reseal the balance shafts where? The seals in the front, the seals on the engine block? Are there seals in the rear? Forgive me for being stupid.
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 01-23-2003, 02:30 PM
overkill's Avatar
Send a message via AIM to overkill
Todwic, you can reseal both balance shafts without having to remove the whole block? What about the rear crank seal?
{1987}944S - (SOLD).
Old 01-23-2003, 02:41 PM
