Painting Hatch Trim - Rubber Black on Chrome?
Wondering if anyone has suggestions on how to paint the hatch trim?
Mine is peeling, and looks previous owners took a try at it and failed.
It looks to be chrome or shiny smooth plastic underneath. The rubber coating comes off in chunks, but I don't really want to try to peel it all off.
Usually the recipe for painting is to rough up the surface, but doesn't look like that was done to the chrome.
Any suggestions?
2002 C4S 105kmiles
Boston MA
Old 12-18-2016, 09:19 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Hoss, try some satin black, Prep the area, masking, sanding, priming and painting. I'm lucky to have all the finish on mine, but in the future I plan to paint all my trim to freshin it up!
Old 12-19-2016, 08:18 AM
Strip it down and prime it with 2 part epoxy primer. Then you can paint it with anything you want
Old 12-19-2016, 06:20 PM
daveurethane's Avatar
Powder coat it ,
Old 04-28-2017, 05:40 PM
944 S2
944 S2's Avatar
Pretty sure it's stainless steel.
Old 04-28-2017, 06:13 PM
I ended up putting Plastidip on it without sanding (although I did get rid of the loose bits) and it worked amazingly well.
2002 C4S 105kmiles
Boston MA
Old 04-29-2017, 06:53 AM
I covered it in satin vinyl wrap that extended about half an inch over the glass. This stopped any water ingress and looks good.
1987 944 Summer
2006 E90 Winter
Old 05-04-2017, 09:09 AM
