What's the name of this gasket?
Hey guys/gals
First what is the name of this gasket that circled in red? Second where can I buy just that gasket? I am getting ready to put my head back together after a port/polish job, 3 angle valve grind, updated w/pump new belts and other misc. parts, I purchased a head gasket set but this gasket either was not included or I have misplaced it! I am not sure where to find this one... Thanks Rob Off topic question: What is the best car care product to remove swirl marks from black paint?
Rob 87 944 * 89 951 "When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car." |
It's part # 928 106 197 04
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Some time ago when I replaced the head on my 951, I installed the parts you have circled in red and did not place close enough attention. The two bolts are of different lengths on my engine because the longer bolt also holds a bracket that holds some piping. The head rebuilder said I did not have to reinstall the bracket. But when I put the bolts in I did not realize that the longer one bottomed. Of course when I filled the engine with coolant, it leaked.
Until that point in time I had never removed a head. So you can imagine the feelings of trepidation I had when the thing leaked - I thought I had cracked the head or something.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
I use either 3M or Mequire Glaze polish to remove swirl marks.
Stay Posted - more to come. |
I recently changed this gasket.
This gasket cames in the head gasket kit |
