Tired Member
DaddyGlenn's Avatar
Question Challenging Electrical Issue - windshield washer
This is bizarre.
My son's 1985.1 944.
New windshield washer pump does not work. I applied power directly to the pump and it works like a charm. I put my multi-meter on the pump wires in place of the pump and can see voltage when the wiper switch on the steering column is pulled. Yet when I attach those same wires to the pump and pull the lever, ... nothing.
Ideas?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-01-2018, 05:11 PM
The power required to work the pump is quite a bit more than what is needed to make the meter work. Look for a bad or corroded connection or a bad or corroded ground.
Good luck, George Beuselinck
Old 01-02-2018, 07:45 AM
Tired Member
DaddyGlenn's Avatar
And that's what it was. Just needed to clean the contacts at the steering column switch.
Glenn
Old 01-06-2018, 07:52 AM
