Oil light flashing 88 924S automatic
Hi my Porsche friends, I know this subject has been up many times in the forum and I have read about all of them on the subject. Anyway my oil light has never flashed in this manner before I have double checked and gone over what others have said to check. Anyway the car is running fine. I taken it out for some test runs, and no odd noises, no leaking fluids, and everything seems ok. I noticed the other day that when I start it in the garage the light doesn't flash, but when I drop it into reverse and start backing out, it starts flashing continually and doesn't stop till I shut it off. I have great oil pressure on my gauge and I've about run out of things to check trying to figure out why it's flashing. I was cautious about at first, but since it's been running great it's just annoying now. And yes I have checked and tested the sensors and cleaned all my grounds etc, etc. Any ideas or assistance would be great, thanks and have a wonderful day all...
Old 06-23-2019, 11:35 AM
9FF 9FF is offline
9FF's Avatar
It’s an oil level problem, either your oil is low or your oil level sensor wire is disconnected or your oil level sensor is toast.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 06-23-2019, 12:49 PM
In the Fires of Hell.....
kdjones2000's Avatar
Buy a new oil pressure sensor and be done with it. The light and the gauge are on 2 different circuits, so one can be fine and the other failed.
It's a common issue - happened to mine while driving down the highway.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Which symbol is it, the oil level or oil pressure?
1987 944 Summer
2006 E90 Winter
Old 06-23-2019, 01:56 PM
It's the oil pressure warning light, that's flashing. If I start it up and just sit there idling no flashing, but as soon as I drop it into reverse and start backing out, it flashes all the time.
Old 06-23-2019, 04:17 PM
I have a new oil sensor on the way from Pelican
Old 06-23-2019, 04:19 PM
I had just recently changed the oil and my levels were ok. I traced the level sensor wire and from what I could tell everything seems to be working properly, but then again I'm no Porsche tech either. I learn something new everyday with these cars. I've owned mine for over 15 years now lol...
Old 06-23-2019, 04:26 PM
rbuswell's Avatar
Porsche Crest Another possibility
I learned from another forum that the oil level light may also flash if the brake fluid reservoir is low. I have no confirmation that that is true but worth checking out I would say.
1982 911SC
1987 924S
Old 06-24-2019, 03:57 PM
