hatch motor arm broken
Is this piece worth repairing? JB weld?
Is it common for these pieces to break or is something going that causes this? http://forums.pelicanparts.com/uploa...1520614395.jpg |
JBWeld won't hold it together if that's what you're asking. They're tiny, thin, cheap metal parts that are basically designed to break rather than the motor or cable. You don't need it unless you pop your hatch from the drivers seat. It isn't used if you use the key from the back.
And you can buy a replacement from Porsche if you are so inclined and have $130 to shell out for literally 2 cents worth of pot metal. Yes, one hundred and thirty dollars for that... https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&LastVisited_i nput=944M&make=POR&description=944.624.824.00 |
Ouch!
My hatch won't open with the key either. So I have to get in there and open it manually to adjust things I suppose. |
So I got the hatch open from the inside. And it looks like nothing can open the hatch but the motor?
Is that right on an 89 s2? I turn the key and the motor runs but I don't see any cables that would open the hatch should the motor go bad? |
What unlocks the latches are the rods from the lock to each latch.
Hmmm on some web stores PN 94462482400 works from 84 944 on up and some say up to 88.
I am guessing they are all the same though. In the meantime I am going to clean everything up. What grease are you guys using? Thanks for all the help! |
I have one laying around in the shed if you want it (spare parts from an 84 I stripped a few years back). I believe in paying it forward. If you want it send me your address info and I will drop it in the mail
I have a 1988 porsche 924S. Mine is also broken. Does anyone have one of these for sale for a 1988 and up? They are different from the early model.
| All times are GMT -8. The time now is 07:01 AM. |
