Flexeplate
1986 PORSCHE 928 4.7 S2
CHECKING FLEX PLATE FRONT AND REAR BOLTS.
How do you move shaft with the splines 2mm towards gearbox to line bolt up .Doesn't seem to want move when tap it with hammer.
Old 03-25-2025, 09:53 AM
stepson's Avatar
I've always used a long pry bar
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 03-25-2025, 12:09 PM
HI
Thanks for that.what do you lever it off
Old 03-25-2025, 01:05 PM
Banned
To move the shaft 2mm toward the gearbox on your 1986 Porsche 928 S2:
• Loosen the flex plate center nut slightly to relieve preload tension.
• Then gently tap the shaft rearward with a plastic mallet or brass punch.
• Ensure the shaft isn't binding due to rust, misalignment, or lack of support.
• Don't force it, it should move once preload is relieved.
Old 05-01-2025, 05:49 PM
