Ratcals's Avatar
Post Car runs bad when cold
I have a 1986 951 and unless I let it warm up for about 10 minutes it runs real bad. If I step on the accelerator too hard it seems like it want to stall and it idles rough. Once it is warm it runs just fine. Any suggestions?
M
Old 03-06-2004, 09:34 PM
Iggy's Avatar
Sounds like a temp sensor is bad.
Old 03-07-2004, 11:56 AM
..P ..P is offline
I had the "exact" same symptoms on my '83. I changed out the plugs, wires, rotor, and the Temp II sensor. Finally changed the Thermo Time Switch and fixed it. Both the Temp II sensor and Thermo Time switch are right up front near the thermostat where you can get at them easily, and they both look like a water temp sensor unit for a temp gauge. They both send a signal to the CSV (cold start valve) located under the intake manifold.
The fuel line check valve can make the car hard to start, but what you described seems to be a classic Thermo Time Switch and/or Temp II sensor issue.
Good luck, the parts are generally inexpensive and easy to change out.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 03-23-2004, 07:54 PM
